Where is a place where I can get an amp around 1200watt I need an amp to power 3 12" subs each rated at 1100watts what kind of sub and what watage do I need?
Trent
~REFS~
-CA.com-Gianotti(2 18" FI BTL D1) Slowd N Throwd(Wiring),Ebrunn(PC monitor),Rab(HK4000D)
-SMD.com-Nismofreak(Radar),BigP(Phone Headset),anonymous(Xbox360 Headset)
Trent
would that be 1100 rms each or 1100 max each?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
rms is 600 each and 1100 max
~REFS~
tkit...max power doesnt exist bro...always follow rms ratings, thats what you should feed your subs...so you'll need an amp that supplies @ least 1800 rms watts ;)
-Fink
Edited by finkster
Eclipse cd7000
So you have three 600W rms subs. What subs are these and What is the final ohm load?
2001 Blazer
Pioneer 5900IB - (2) DC Level 3 10"s - Sundown 1500D
2 12" dual and 1 12" jensen the dual I know is impendance 4ohm not sure on the jensen
~REFS~
well you definitely don't want to hook all three subs up, seeing their a mix and match. if money is an issue then just roll with the two duals and get a 1200 rms amp.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Well right now all iv got in the box are the 2 duals on a 400watt amp and I was going to put the jesnen in tomorrow but I really want a bigger amp
~REFS~
wowsers u cant mix brands wtf..lol for real tho itl sound shitty bro.......
Eclipse cd7000
  • Who's Online   1 Member, 1 Anonymous (See full list)
