Ok im hooking up my buddys system , he has 2-12" Kicker CompVR subs and he has 2 Pioneer 2 Channel 760W max Amplifiers.(1 to each sub) and i was wondering if i wire each sub to 1 ohm how many watts will each sub get?
Crossover: Active crossover
Additional Features: Gain control
Response Bandwidth: 10 - 50000 Hz
Signal-To-Noise Ratio: 95 dB
Continuous Power / Channel Qty: 125 Watts x 2
Amplifier Output: 2-channel
High Level Inputs: Yes
Input Signal Voltage: 0.2 - 6.5V, 0.8 - 26V
Crossover Slope: 12 dB/octave
Low Pass Frequencies: 80 Hz
Bass Boost Frequency: 50 Hz
Bass Boost Gain: 0 to +12dB
Output Power / Total: 760 Watt
Distortion Factor: 0.015%
Amplifier Output Details: 125 Watt - 4 Ohm - 20 - 20000 Hz - THD 0.2% - 14.4V DC - 2 channel(s) ¦ 190 Watt - 2 Ohm - 20 - 20000 Hz - THD 0.8% - 14.4V DC - 2 channel(s) ¦ 380 Watt - 4 Ohm - 20 - 20000 Hz - THD 0.8% - 14.4V DC - 1 channel(s) More Information Model No.: GM-520T
Shipping Weight (in pounds): 8.6
Product in Inches (L x W x H): 13.0 x 12.0 x 2.4
not only is this amp NOT 1 ohm stable the total power ratings are even at 14.4 volts and the THD is .8-- not good SQ at all
Edited by bassINyoFACE
I got banned for being an ignorant ass....and im a dickhole
i like men, michael jackson and large sausages
basically he is saying if the amp gets a constant 14.4 volts with no drops, then it will put out about 380rms, but when the bass hits a system with out adequate power supply, the voltage will drop about 10.5-12volts, in other words in a real world, those amps would be putting out about 10-20% less than rated on a average electrical system
  • 4 weeks later...
wow yea this amp sux balls i know i have one hooked up to an old 15" kicker
it sounds alright but its needs to be cranked to get some volume out of it and it has major heating issues and cuts out alot
basically its classified as a P.O.S from wal mart
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
  • Who's Online   1 Member, 0 Anonymous, 4382 Guests (See full list)
