chapo123 Posted June 17, 2010 Author Report Posted June 17, 2010 i was planning on using 8 gauge but the terminals on the subs are too small and it was a bitch to try to get that wire in.. and no its not a threaded connection. and maybe the wire loose too cuz i left the wire long (from the nut to terminal) so it has some slack so the wire doesnt comeout again and make it do 1 coil again LOL Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
chapo123 Posted June 17, 2010 Author Report Posted June 17, 2010 You could do dirrect leads through the port if you want from sub straight to amp how? i would either have to connect em somehow.. i could do that if i had 1 sub lol but i need to wire them together so they need to touch atleast once. Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
AKBass Posted June 17, 2010 Report Posted June 17, 2010 how? i would either have to connect em somehow.. i could do that if i had 1 sub lol but i need to wire them together so they need to touch atleast once. A yellow butt connector since you dont want to solder. Really the wire nut should have been fine IF all 3 wires were making good contact with each other. what about the other wire nut on the other sub? Current Ford F350 Alpine IVA-W505 2x Diamond s600 1x Diamond S400 2x RF T1500-1BD 1x RF T600-4 2x AA Havoc 12" DC Power 230XP 1/0 throughout Up Next 95 2dr Tahoe Head Unit= Alpine IVA-W505 Components= 2 Diamond S400, 2 Diamond S500, 2 Diamond S600 Woofers= 2 10" Diamond Hex, 2 12" Diamond D9 Amps= 3 RF T1000-4 Processor= 2 RF 3sixty.2 Subs= 4 18" AA Mayhem Amps 4 RF T2500-1 BDCP 7 XS Power D3100 3 DC Power 270+
chapo123 Posted June 17, 2010 Author Report Posted June 17, 2010 this nut wire was for both subs. pos. the other one is perfectly fine.. i have a pic of what the wires look like that i just took when i took off the nut. Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
Jeremy1998 Posted June 17, 2010 Report Posted June 17, 2010 Friends don't let friends use wire nuts!!!!! No they don't! what else am i supposed to use? Ither solder the two wires directly together and the heat shrink or use crimp ocnnectors and solder them... i really dont wanna soldier.. It is not scary... It is alot safer than burning to death in your car...
Red-navi-916 Posted June 17, 2010 Report Posted June 17, 2010 You can connect them all together with a yellow buttconnector and then you can use electrical tape to secure them.. There is more reasons then 1 why your wire is lookin all toast, but you won't know, I have ran straight bolts for over 2 years and never had a problem but it could be a few different things lol... BUILDLOG http://www.stevemeadedesigns.com/board/ind...showtopic=61862 "98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!! Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
chapo123 Posted June 17, 2010 Author Report Posted June 17, 2010 well heres a pic of the wires.. look burnt.. so confused whyd the pos do it but not the neg? maybe a loose wire? i would try to redo it but im pretty scared to burn down my car. Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
chapo123 Posted June 17, 2010 Author Report Posted June 17, 2010 i guess im lucky it didnt kill my subs? Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
IH8PunkRok Posted June 17, 2010 Report Posted June 17, 2010 something arced in there no idea what would cause it though -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
chapo123 Posted June 17, 2010 Author Report Posted June 17, 2010 whats arced mean lol Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
