IH8PunkRok Posted June 17, 2010 Report Posted June 17, 2010 when electricity short circuits through the air or across something that isnt supposed to be there. like lightning very dangerous -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
chapo123 Posted June 17, 2010 Author Report Posted June 17, 2010 my only guess i can have is that it was a loose wire? i really dont know what else.. Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
AKBass Posted June 17, 2010 Report Posted June 17, 2010 whats arced mean lol when it arcs there isnt a good connection between wires. Like an electronic spark on a lighter or a barbeque but they are designed to do that, connections in your system are'nt. Current Ford F350 Alpine IVA-W505 2x Diamond s600 1x Diamond S400 2x RF T1500-1BD 1x RF T600-4 2x AA Havoc 12" DC Power 230XP 1/0 throughout Up Next 95 2dr Tahoe Head Unit= Alpine IVA-W505 Components= 2 Diamond S400, 2 Diamond S500, 2 Diamond S600 Woofers= 2 10" Diamond Hex, 2 12" Diamond D9 Amps= 3 RF T1000-4 Processor= 2 RF 3sixty.2 Subs= 4 18" AA Mayhem Amps 4 RF T2500-1 BDCP 7 XS Power D3100 3 DC Power 270+
chapo123 Posted June 17, 2010 Author Report Posted June 17, 2010 so basically a wire was loose or not touching enough and when the bass was hitting it was moving the loose wire causing a spark everytime it moved away?? sounds like the explanation but im still kinda scared lol Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
IH8PunkRok Posted June 17, 2010 Report Posted June 17, 2010 my only guess i can have is that it was a loose wire? i really dont know what else.. you can wonder all you want. you may never know. go hook it back up but this time do it better. if it happens again then start a full investigation just be on your toes for a while. -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
chapo123 Posted June 18, 2010 Author Report Posted June 18, 2010 the thing is im really scared because its a trunk car and the back seats dont drop down so i cant tell if it smokes... Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
chapo123 Posted June 18, 2010 Author Report Posted June 18, 2010 plus it was hard to get all the wires in cuz my middle finger is broken so it was difficult LOL Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
Red-navi-916 Posted June 18, 2010 Report Posted June 18, 2010 Yup that's the case if it aint tighht enough that's what will happen BUILDLOG http://www.stevemeadedesigns.com/board/ind...showtopic=61862 "98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!! Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
Anotherguy Posted June 18, 2010 Report Posted June 18, 2010 The three wires in the wire nut weren't making a good connection causing resistance or arcing which makes heat. There isn't anything wrong with using wire nuts. Strip back plenty of insulation, twist the wires together by hand clockwise then screw on the wire nut. The use some electrical tape to secure the wire nut. You should be using tan wire nuts as they are made for three 12 awg wires.
chapo123 Posted June 18, 2010 Author Report Posted June 18, 2010 thats what i was doing. i thought to my self it was tight enough because while i was shaking it to make sure i had my dmm hooked up to the leads and it wasnt changing the ohm load. i twisted em together then screwed on the nut. then wrapped in electrical tape. Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
