when you say good battery what do you mean? you want the XS in the back with your audio gear, keep the die hard up front as your stater. but here is some food for thought, even though your putting that XS battery in the back you don't want to throw it in the system with a very old week battery up front, if the die hard is old or not keeping a good charge you might want to think about getting a replacement for it because it may shorten the life of your secondary battery.
That is one of the most important things to keep in mind when it comes to doing multiple batteries, in my opinion. One junk battery will shorten the lifespan of any other good batteries hooked up with it. just remember wiring two batteries in parallel will increase amperage, wiring them in series will increase voltage.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
so for example, if i had 2 batts wired in parallel it would take less strain off the alt thus stabling my voltage? or am i wrong?
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
it will help yes, have you done your big three upgrade? doing the big three is also a key component in helping your electrical system. if all your running in your system is what you have in sig. than the second battery and the big three is all you should need to help your voltage.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
thanks for the help, and sorry for the thread jack, but im not worried bout my system now its when my dc comes, running roughly 2k on a stock 130 amp alt is a lil sketchy to me, big 3 i havent done(nor would i know how to go about doing that with a stock alt), but i plan to either run 0g or 2g dunno yet depends on my money situation
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
