Entent Posted June 22, 2010 Report Posted June 22, 2010 hi i have a 2002 Acura RSX and i just bought 2 DC lvl 3 12's and a Soundstream pcx1500d my subs are dual 4 ohm so im wiring them down to 1ohm im wondering if i can run this off the stock electrical. thanks Subs: 2 Dual 4 DC lvl 3 12's in ported box 34hz tune wired to 1 ohm Hu: Eclipse 5425 Amp: Soundstream pcx1500d
OrionStang Posted June 22, 2010 Report Posted June 22, 2010 At least do the big 3. Then see how bad the voltage drop is when your bangin those 12's. Whats the output of the stock alt? SMD Super Seller My Feedback Thread
OBI Posted June 22, 2010 Report Posted June 22, 2010 Yes you can. At most all you'll need is a bigger batt. (Waiting to see all the you need a H/O alt, and 3 batts posts.)
Guest Posted June 22, 2010 Report Posted June 22, 2010 yes you will be fine. im running a hifonics bx1605d AND a rockford fosgate 200a4 on a stock electrical system with big 3 in 1/0 gauge.
Entent Posted June 22, 2010 Author Report Posted June 22, 2010 ok thanks alot guys stock alt is 90amp Subs: 2 Dual 4 DC lvl 3 12's in ported box 34hz tune wired to 1 ohm Hu: Eclipse 5425 Amp: Soundstream pcx1500d
BulletInjection Posted June 22, 2010 Report Posted June 22, 2010 You need a 360 amp alt and at least 2 D3100's My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection
OBI Posted June 22, 2010 Report Posted June 22, 2010 You need a 360 amp alt and at least 2 D3100's LOL... YES!!!
BulletInjection Posted June 22, 2010 Report Posted June 22, 2010 Nice double post. My friend is running 2000+ off a fully stock system and he drops to 12.2-ish so id say you are pretty safe but the longevity of that battery cannot be determined. I would of course recommend a dry cell. My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection
