i got two 15" fi audio bl's fully loaded on a massive audio p3000.1 which is 3000 watts rms @ 2ohms, the problem is my subs are dual 1 ohm (more like dual .75), should i run them @ .75 or 1.5? the manual for the amp says 2 ohm mono or 1 ohm x 2 can anyone help me? i know the fi's can take it but will the amp? i have a kinetik 1400 in the back and stock under the hood with two runs of 0 guage and a stock alt.
Edited by Nu_South_Audio
well the sub are dual .75 ohm so i would have to wire each sub in series, then parallel to get .75 ohm or series to get 3 ohm, right now there at 1.5 in each channel. on the term lab it hit a 146.0 @ 46hz
or bridge the amp, but put the subs in series. that way you get around 2 ohms and get your full 3kw
youll be safe running that amp at 1.5 because I highly doubt your reactive load is going to be under 2ohms.
2006 SPLMAX Bass Race Competitor of the Year
2006 Bass Race 156 points
Team DC Sounds
Team Maxxsonics
Team HR
Team Second Skin
Team Hooker Audio
http://dcsoundlab.com/
2008 Starting from scratch
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
