It makes somewhat sence. However, i don't see why it "wouldn't" work. All I want is to send signal to both amps. Nothing more, nothing less. I've used preamp outputs before, just not like this. I'm not looking to get fancy shmancy here lol, Just want my signal to be split; if that makes sence. Explain how using those preamp outputs on the amp wouldn't work? It's just another way of sending signal correct? If I plugged a male to 2 female y splitter into each preamp, then ran a set of rcas from the females to the inputs of the second amp, wouldn't that work?
Also just to make clear, i'm talking about the "line out" rcas on the amp.
Edited by Alex K
2006 Nissan Z Track.
My Feedback Thread
better yet, here's actual picture of what i mean.
My Feedback Thread
Sorry for the late response Alex. I fell asleep.
Here's the best I can explain it.
If u did daisy chain them you wouldnt be able to adjust the crossovers on the head unit.
Run it like I said a couple posts above.
BUT after looking at the specs of your head unit again, i see a problem. You cant run active off that deck, so do you have active crossovers for the tweeters?
Eclipse cd7000
hmm, I'd get four y connectors with one female end and two male ends, then wire them up like...
dualampwiring.jpg?t=1277740149
Edit: the second one is how I'm doing mine, because my rear outputs have more bass so they will go to the midbass amp. Also, then when I get the crossover I want I can adjust the front on the crossover for midrange and highs, and the rear can be adjusted for midbass.
Edited by lAutruche
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
im going to try every method mentioned here and see which one works for me
My Feedback Thread
