89 Chevy Posted June 30, 2010 Report Posted June 30, 2010 I Just bought a FI BTL 12 that is fully loaded. I would like to know what people are tuning there box's for the BTL's. I was thinking 2.5-2.6 cubic Ft. after displacement, tuned at 34 Hrz. What should my port opening and length be? I wanna try to get it right the first time so I don't have to do it again. Thanks for the help. Elliot
AI James Posted June 30, 2010 Report Posted June 30, 2010 box you have planned should be fine off rms wattage , do abotu 15sq per cube imo
89 Chevy Posted July 1, 2010 Author Report Posted July 1, 2010 box you have planned should be fine off rms wattage , do abotu 15sq per cube imo I emailed Nick at FI, and he told me this...........A 4x10" port will be 33" long in order to tune to 33Hz. A 5 x 9" port will be 38.55" long in order to tune to 33Hz.. Doesn't that port sound a little big??
J-Lane Posted July 1, 2010 Report Posted July 1, 2010 I emailed Nick at FI, and he told me this...........A 4x10" port will be 33" long in order to tune to 33Hz. A 5 x 9" port will be 38.55" long in order to tune to 33Hz.. Doesn't that port sound a little big?? From Fi's web site: Enclosures: BTL 12 – Ported box we recommend using 1.75-2.5 cubic feet @ 30-35Hz (I personally think that a 32hz tuning is optimal, and has the most output and is still the most musical daily driving). Use 12-16 square inches of vent area per cubic foot of volume. So if you use 2.5 cu ft you would want about 30-40 square inches of port area. In the comment I quoted above from Fi's site they say 32 Hz is best, so for 2.5 cu ft with 40 sq inches of port area lets use 4"x10". I use Bass Box Pro and it says the port length would be 38.94 inches long.
BTL FTW Posted July 1, 2010 Report Posted July 1, 2010 It'd be Easier to run a T-Line. I have a BTL12 in a T-line tuned to 26hz and it's clean, clear loud and pounds Alpine F1 Status DD CS6.5 x2 Front Stage DD 9512H DD M4a @ 2 ohm DD S2b @ 8 ohm per channel I run high ohn loads for MASSIVE headroom and cleaner SQ 270amp alt D2400 up front D3100 x2 batter in back
Ray Posted July 1, 2010 Report Posted July 1, 2010 you guys a t lined btl's..lol 40sq in is perfect. I would make the box like 15 tall, and the vent 13.5x3x 33long 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
BTL FTW Posted July 1, 2010 Report Posted July 1, 2010 you guys a t lined btl's..lol What's wrong with a BTL in a T-Line? Alpine F1 Status DD CS6.5 x2 Front Stage DD 9512H DD M4a @ 2 ohm DD S2b @ 8 ohm per channel I run high ohn loads for MASSIVE headroom and cleaner SQ 270amp alt D2400 up front D3100 x2 batter in back
