Kicker Trunk Build **2-10's=150.2dbs**
i would think add a run of 0 gauge from the negative of the front batts to each rear batt. replace your fuses appropriately. id say 250s in rear bank from front and also to the amps. maybe ground amps to the batts?<--thats what i do. idk if it helps or not
the amps do not have fuses in them and the reason i have 100 amp ANL fuses from the back betteries to the amps is due to the MECA class im in. I also was thinking of taking out the Stinger 150amp curcuit breaker and put an 300 amp ANL fuse. all the wires are 1/0ga.
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
i would also do a jumper power wire 1/0 from back batt to the other back batt and a neg while your at it
So a positive run from rear batt. to rear batt? fused on each end?
man that trunk looks damm good! wish i could do something like that but my back seats dont lay down :angry:, got any during the build pics? looks great!
Thanks, you can always port it threw the rear deck. the only pics i have are the ones posted the camera that had all my pics i lost
yea, take out the circuit breakers, i had some and they would get hot after 10 or 15 mins of playing and pop for no reason, and they can where out each time they pop. and keep the fuses the same 300 front and back, even if you did a circuit breaker it should be a 300 amp.
and i would do a jumper wire too, to connect the back batts together.
i would also make the fuses easily accessible and keep some 250 amp fused for them and just switch out to the 100 amps for comps.
^^^^ this cause you will double your power and them 100 amp fueses are gonna blow
You could do a fuse on each end of the jumper to be super safe about it
fuses are easily accessible. kicker recommends 300 amp fuses to the amps
def do a run connecting the pos of each back batt.. neg too.. less resistance=moar powa
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
  • Who's Online   0 Members, 0 Anonymous, 481 Guests (See full list)
