So. I have 3 12" Kicker CVRs, which are 2 ohm DVC. They are currently wired series/parallel, for a total ohm load of 1.34ohms.
I just want to know, if I were to run them at 1.34ohms on a 1000 watt amp (namely a Rockford Fosgate P1000-1bd), how many watts would each subs be seeing?
And could you tell me how you get to whatever number it is that you tell me?
Thanks.
On 2/28/2013 at 2:52 PM, Chaise said:
"Now spread your butt cheeks so I can zap your asshole."
look at the birthsheet. you'll get whatever the rms is between the 1 ohm and 2 ohm load ratings, leaning towards the 1 ohm number instead of exactly in the middle of the 2.
^^^ This. To get a more accurate idea, subtract the 2 ohm wattage from the 1 ohm wattage, multiply it by 2/3, then add it to the 2 ohm wattage.
Example: 1000w rms @ 1 ohm, 500w rms @ 2 ohm
1000 - 500 = 500
500 * 2/3 = 333
500 + 333 = 833
It's not exact but it'll get you kinda close to where you're at. No real way to know without clamping it.
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
So, in theory, that would mean I would only be getting about 277 watts per sub? (Mathematically speaking.)
Meh, probably lots more than that. The T1000bd puts out at least 1200 rms @ 1 ohm (I've seen birthsheets that say nearly 1600 rms @ 1 ohm), so I'd say your subs will be getting up near their rms rating. The CompVR is rated at 400 rms (the new model) so if your amp does around 1400 rms @ 1 ohm, your subs will see about 400 rms a piece.
wtf is lolcats?
Alright thanks for your help!
he is talkin about the p1000.1 all the p1000's iv seen the birthsheet says 1300 to 1400. the one i had was 1407
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
I agree, usually see about 1200+ on birth sheets...
1250 is what I usually guestimate most p1000's to be also.
Not as strong as the t1000; but not a bad amp tho.
Clicky for build log....
2002 Tahoe
DC Power Inc 3 alt bracket with 2x230a. alts 1 stock
Eclipse CD5030
2 JL HD 600/4
4 Rockford Fosgate 2500bdcp's
4 DC Audio 18" XL's
4 Pr MB Quart Premium Components
200FT Stinger HPM 1/0
Rockford 360.2
No where near enough sound deadening
Oh, my bad. Totally missed that I was looking at the wrong amp. It's all good though. As long as your amp is above 1200 rms @ 1 ohm you should be all set. Thanks for catching that guys! :good:
wtf is lolcats?
