Heres the problem. When I move a switch on my switch box (for the air suspension) my subs bottom out. They pop very hard. It only happens when you let off the switch, like when you push it down its fine, but when you release it, pops hard. To me this sounds like a ground issue. Im just not sure how to fix it, not sure you guys can help with that not knowing my set up, but any ideas would be great.
Valves are in the rear of the car, power ran off fuse box, grounded to the sub frame rails. Amps are powered and grounded to the rear batteries. all of the rear batteries are powered and grounded to the front of the vehicle. Just some info on the set up.
What do you think? I may also need to move this to the suspension thread?
Xterra * 69 Camaro * Audi S5
36 Ford * 51 Mercury
looking for wire sponsor :)
www.flyracing.com
If it were me I would ground the Rear batteries straight to the frame.
Well the rear batts are grounded to the rear subframe rails, and the front subframe rails, There isnt much of a frame on this car (93 civic hatch). I tried to change my ground on the valves also, didnt seem to change anything. :pardon:
www.flyracing.com
did you say you have your amps grounded straight to the battery??? ground your amps to the chassis
Yeah never thought of that. Try what speedball said and see if it fixes the issue.
muahahahaha i love it when i'm called speedball reminds me of when i played baseball as a litle kid running around in circles and didn't know which base to run to lmao
  • Who's Online   0 Members, 0 Anonymous, 1623 Guests (See full list)
