Hi all,
I am finishing up my mid/high speaker build, got the back 6x9's in with some fat-mat underneath each, and now I'm working on the front components. I would like to mount the tweeters on my door panel, right in front of the door handle, which is exactly 1 foot above my mid woofer (so the imaging should be good) the problem I am having is i would like to flush mount my tweeter, but the door panel is quite curvy. The place where I would like to mount the tweeters is slightly curved, almost flat but not quite. From the looks of it, if I drilled my hole and flush mounted them inside, the top and bottom of the circle border would have a bit of gap. The tweeters are from JBL p660c. How would I make it so that the border of the tweeters has no gaps all the way around? If not, is there anything I could do to mold the tweeter housing/borders or something I could maybe fill the gaps with?
Thanks a lot guys!
2018 Golf R - Stealth SQ system build - C508GTI front (active), 2x Pioneer Z10LS4, Zapco DSPZ8, Clarion DPX11551 (Mono amp), Pioneer GM-D8604 (front stage amp), Pioneer GM-A3702 (rear fill amp)
SOLD! 2011 Subaru STI - 'modest' passive sq system - JBL p660c component (front) JBL P662 (rear) JBL W10GTI (sealed enclosure) 4ch JBL GO1004 (150RMSx4), Clarion DPX11551 mono amp (+-1200RMS@3ohms)
unless you want to remould the doors you could remove the metal grating style cover and reshape it but still make it replaceable onto the speaker casing if you know what i mean
Live life to the full... Then TURN THAT BITCH UP!
Do you have pictures of the door panel. Unfortunately I can't really picture every thing.
i"ll try and get some pics uploaded.
I'm thinking maybe I'll be able to heat up the plastic ring and bend it slightly in order to contour the panel...
here's some pics of where I would like to mount the tweeter, and also to give an idea of how the gap is using a flat round piece from the mounting hardware;
Any suggestions/ideas would be great! thanks again guys
Bump for some help!!! Want to get started on these this morning!!
  • Who's Online   0 Members, 0 Anonymous, 1361 Guests (See full list)
