Please Help!
Ok so to start i have a 03 chevy cavalier, and i did the big3. i have 2 18's walled, with a crescendo 3k, My question is, do i need the voltage isolator to charge my back batts or no? because if i just have to do runs to the back thats fine. i think the isolator is killing my voltage. please help me im tryin to get this done right now while its still some what warm out before it gets hot
2003 CHEVY CAVALIER
2 FI BL 18's/ Replacing Soon
Sundown Saz 4500D
Iraggi 320mp alt
PIONEER AVIC N2
Soon to be Running 7batts
WALLED
My you tube channel
no an isolator is not needed
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i have no isolator on mine and my back batts are just fine actually when i took them out they were reading higher then before i put them in.
I thought an isolator was to keep the front batt from discharging when the car is off, and ur playing music. i might be wrong, but i thought thats what people have them for.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
Ok thank you. it is going out then! i knew i would get a quick answer on here. thanks again.
2003 CHEVY CAVALIER
Sundown Saz 4500D
Iraggi 320mp alt
PIONEER AVIC N2
WALLED
My you tube channel
Thats exactly what its for. Just as it states, it Isolates the front battery from the rear ones.
and can actually kill your alternator faster than just not using one.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
well i think i might have kind of killed my stock alt then. haha well i took it out and did another run of 1/0 to the trunk and does sound a little better. and voltgae drop isnt as bad. just need a new alt. getting that soon.
2003 CHEVY CAVALIER
Sundown Saz 4500D
Iraggi 320mp alt
PIONEER AVIC N2
WALLED
My you tube channel
Just make sure to check what the voltage is on your batteries from time to time. AGM type batteries will rest between 12.8 to 13 volts when fully charged, if you see them resting at less voltage charge them up.
  • Who's Online   0 Members, 0 Anonymous, 1347 Guests (See full list)
