i did what the manaul said to do would a bad ground make this happen because i did relocate the ground
Yep, it could be a ground. Did you sand off any paint or rust?
Also, is the impedence too low?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
i just hooked it on the set mount and sanded the paint how u know if the impedence is to low
Impedence is the same thing as ohm load. AQs are rated at 1 ohm at the lowest
LMFAO so true
:blush:
Hmmm....you did it just like the manual says, good ground, plenty of power.....? Master amp to master output, and slave to input slave, checked all connections?
"loud 'cause its clipped like a 7yr olds buzz cut" -Decaf
"unfortunately i'm still tuned high as Giraffe pussy" -Twistedchild420
ok possible problems i could see...
- Bad Ground - Sand off and connection areas
- Voltage drop - check your voltage with a meter while turning up the volume
- amps mounting - make sure they are not touching metal.
- Impedance is wired too low - try wiring in series instead of parallel
Other than that id own up and say i have no clue...
Live life to the full... Then TURN THAT BITCH UP!
  • Who's Online   0 Members, 0 Anonymous, 1766 Guests (See full list)
