Whats Louder? Many Low Power or Few High?
food for though, i had 3kwrms on 2 hdc 18s and switched to 4 15" sdc's and it was way louder.
Dammit.. I was either going with 2 18" HDC3s or 4 SDC 15"s for my blowthrough and I just got one of the 18"s..
2010 Focus coupe- 8 12" wall. 157.5@46hz
2016 Focus ST - SQ build.
simple math. pi * (radius^2). but...you dont want to use the full radius as the whole surface of the speaker isnt exactly being used.
Yes thats simple math of course but subs dip down they aren't flat doesn't that have to come into place somewhere?
Return it! ha
Red
Also if having more smaller speakers is better than less big speakers why don't more people have that type of setup. Steave has 4 18"s not 10 15"?
i think his set up had to do more with being able to use it as a daily driver still, with the backseats intact. sometimes its more practical to do such things. whatever youre comfortable with doing, do it.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
Thats a wayy legit response. Never thought about it that way.
Not trying to start an arguement this is more points for him. Hed probably find a way to fiberglass his whole trunk area to fit like 20 speakers there ha
Red
So for everyones information I have changed my entire layout of my trunk. (THIS ARE ONLY PLANS STILL NEED TO RAISE MONEY)
1 - 10"
6 - 12"
2 - 15"
This is ONLY the trunk :woot:
I suck at draawing but im going to try so i can get a mental picture on the web
Red
If you take the time to go though the many builds on this site you will see builds ranging from 2 10s in a trunk doing low to mid 150s to multiple 18s in an suv doing similar numbers. This is just my personal opinion on how I would go about choosing what setup I want to use. First determine how much airspace you have to work with. After you have your total airspace now you can start searching for the subs and quantities that fit your airspace. Too little or too much cuft per sub will drastically effect the end result. Going by the factory specs for airspace required for each sub is a good place to start. After you choose your subs then find an Amp or 2 that will put out the power that your subs need. Now the most important part for me is the electrical system. Make sure that your alternators and battery can handle the extra wattage that your system will be drawing. Some cases you can just do the big 3 up front and possibly add a second battery and you will be ok but just to be on the safe side a HO alt is never a bad idea.
As I said this is just my opinion and I am sure there are many more out there. But there are just too many things that go into building a loud system that the argument between low power and cone area or high power and fewer subs. The best example I can give of this is a friend of mine was running 6 15s on 5k and maxed it out 148.5, then changed down to 2 15s on the same power and gained 1 db. The only difference was how the box was built.
Hope some of my early A.M. rambling makes sense
  • Who's Online   0 Members, 0 Anonymous, 866 Guests (See full list)
