BigRed Posted July 10, 2010 Author Report Posted July 10, 2010 Thank GAWD, someone on this forum with a brain. What is SD? Red
VIP3R Posted July 10, 2010 Report Posted July 10, 2010 What is SD? Sd Measured in square metres (m²). The effective projected area of the cone or diaphragm. It is difficult to measure and depends largely on the shape and properties of the surround. Generally accepted as the cone body diameter plus one third to one half the width of the annulus (surround). Drivers with wide roll surrounds can have significantly less Sd than conventional types with the same frame diameter. 2 Sundown Audio SA-10s Box built by Speed of Sound Kicker 1500.1 Infinity Ref 475a Rockford Fosgate T1682c 6x8s Pioneer Premier DEH-510UB XS Power D6500 Stock 130amp Alt Big 3 Build Log
Forevrbumpn Posted July 10, 2010 Report Posted July 10, 2010 BigRed, I read about 1/3rd of this thread, I got instantly annoyed with the design concepts Okay, reason why NOT to miss match subs...... 1) different size cones, do move at different rates due to mass, and air displacement 2) ALOT of woofer manufacturers use different coils, motors, suspension set ups just going from the same product line 10" to 12" to 15 3) using even same woofers, at different locations in the car will cause phase issues 4) phase issues with everything about this build But you did say you will be using matching 18s now, good work If you ever do miss match subs, make sure they are tuned an octave apart say 30hz and 60hz, and cross them over correctly I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
