Power Steering Hard To Turn Bogs Engine
So yea for as long as i remember the steering wheel has been hard as hell to turn when stand still. when i turn the wheel the engine bogs. power steering fluid is full and belt is tight (car has like 4 belts attaching different shit)
so yea opinions on what it might be?
Bad old fluid. My moms Windstar had a similar issue and using something like a turkey "baister"spelling? Suck as much fluid out as you can, fill it back up. Drive the car a few miles around. Suck out as much as you can fill it back up drive around. Do it maybe 1 or 2 more times and you should have cycled all of the fluid.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
Bad old fluid. My moms Windstar had a similar issue and using something like a turkey baster
so you took all the fluid out and replaced it with fresh ATF?
Sorry. My phone cut my post off. Lol. But yeah. Cycle all of the fluid out. It work kn my moms 99 windstar but no promises. Atleast another thing to try. Hers made a horrible whine when turning and always seemed a little stiff. Works great now after cycling the fluid though
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
Might just be your steering pump going out
'08 Nissan Titan Pro-4X CC LWB
1.5 Inch leveling kit
DDM 55w HIDs
Interior LEDs
2 RE10D4s in tech12 ported enclosure, US AMPS 800.2
I also read somewhere that it could be air in the lines. Maybe try cycling full left to full right with the cap off a few times and see if it gets better? Otherwise I would definitely say PS pump.
Too many projects, too little time...
I would, if you're good with a wrench and have the room, crawl down to your ps pump and remove the lines. Then take compressed air and blow the old fluid, and dirt out. If you aren't that inclined, then use a baster and pull as much out as you can. Only need to do that twice. I would also check, and see if your car uses atf or power steering fluid. I know in my truck its either, but newer cars require power steering fluid only.
1985 Chevy Silverado Black and Silver SBC 350/700r4
ATF??? no. power steering fluid. ATF and PS fluid are a different viscosity
Car: 2003 Lincoln Town Car
Subs: 2 MTX 8512-44
Amp: MTX TA7801
Power: Stock Alt/Battery
Wire: 0 Gauge Stinger Power/Ground
HU: Dual XDVD8181 7" Monitor
Other: 2 Farad Power Acoustik Power Cap
Automotive Technician at Bryden Motors, Beloit WI
