What's the purpose of a shorter belt for an alternator
I'm about to install a new alternator rated at 300 amps and I want to know why I need a shorter belt. Would I will notice the difference with a shorter belt? I've been looking around the forums for info but nothing.
It's over 9000!!!
You only need a shorter belt if it has a smaller pulley. You want to keep tention on the pulley but don't want it too tight as it will wear out the bearings quicker.
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
I'm going to venture a guess and say the new alternator must have a smaller pulley or something. The smaller pulleys are done so you can charge more efficiently at idle. Otherwise, you'd need the same length belt as before, right? Since you didn't have any replies, I thought I'd throw in my worthless opinion. Good luck on getting an educated answer.
Stetsom 11K2d
6-12" DC XL's
8 batts
Ohio Generator alt
2 punch 400's, 8 goldwood 6.5's, 4 selenium st200's
2010 MECA AS1 champ 146.7
Team DC I'm on the wagon, driving a wagon!
'90 Camry Wagon
155+ on music
member of MECA, FCBC, and IASCA
smaller belt = faster rpms = more idle amps.
2006 Nissan Z Track.
My Feedback Thread
The length of the belt doesnt change anything except how tight the belt it, as does your tensioner. If the diameter of your new pulley is smaller you may need a smaller belt, if you cannot adjust it far enough. Other than that it makes no difference. Yes the smaller pulleys are used to help with consistency at idle. Hope this helps...
Edit: a shorter belt wont change the rpms of the alt. Pulley size changes your revaluations per minute..
Xterra * 69 Camaro * Audi S5
36 Ford * 51 Mercury
looking for wire sponsor :)
www.flyracing.com
Thanks everyone for the quick replies :clapping: , I got the idea now. I kinda figured that would be the only reason for a shorter belt. Again thanks. :good:
It's over 9000!!!
Need to find out what rpm's the new alt does the best at, then find out what the rpm charge rate for your stock alt are... If they are around the same rpm for output then stick with the same size pulley, and if not you may have to purchase a smaller one
1999 Chevy S102 Sundown Zv3-10's1 Sundown saz-4500d2 sets of Sundown CS6.5 Comps. (Doors)
2 10" Sundown NeoPro 10's (Doors)1/0 KnuKonceptz - Power x2- Ground- Big 3
300 Amp External Regulated Excessive Amperage Alt
147.8 Sealed Mic on Windshiled148 30sec. Average Drivers Door open Mic on Windshield
Check Out my YouTube Channel --->>> http://www.youtube.com/user/dmntyo2007?feature=guidehttp://www.stevemead...ld-competition/
  • Who's Online   0 Members, 0 Anonymous, 1606 Guests (See full list)
