Hey guys,
I was working on my trunk layout and finished wiring up the two amps. Everything works, except my subs are a lot less loud than they used to be (before I added my 4-channel amp and new speakers) I checked the RCA cords to make sure they were connected,I checked all the settings on the amp and they're the same, speaker wires are hooked up, and on my head unit, I have all settings at 0. The subs are working, but not at all how they used to. They're not nearly as loud as they were and can't even keep up with my
Mids and highs. I have the mono amp hooked up to a cap which is hooked up to the battery (fused of course) my 4 channel amp is also fused and hooked up to the battery. PLEASE help me fix this!!!! Thanks
2018 Golf R - Stealth SQ system build - C508GTI front (active), 2x Pioneer Z10LS4, Zapco DSPZ8, Clarion DPX11551 (Mono amp), Pioneer GM-D8604 (front stage amp), Pioneer GM-A3702 (rear fill amp)
SOLD! 2011 Subaru STI - 'modest' passive sq system - JBL p660c component (front) JBL P662 (rear) JBL W10GTI (sealed enclosure) 4ch JBL GO1004 (150RMSx4), Clarion DPX11551 mono amp (+-1200RMS@3ohms)
Hey guys,
what kind of headunit are you using? and are you splitting the RCA lines?
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
I have a clarion max385vd, its a double din. I have RCA's from the deck to the mono sub, and separate RCA outputs on the head-unit for the 4-channel amp, so no need to split RCA's.
Did you unhook the sub amp at all? If so check your wiring to the subs to make sure the polarity is correct
Car - 99 Neon Sport
Batt - 1 Redtop up front On 200A Excessive Amperage alt
Sub - 2 12" Kicker L7's in ~2 cuft @ 36hz each on a Xtant X1001 @ 1 ohm
Front Highs/Mids - JVC CS-FS6 and Infinity 6022i on Xtant A2002
Rear Highs/Mids - None
HU - Pioneer DEH-P8600MP
1/0 wire ran thru entire car aswell as big3
DB - 144.5 @ Dash.
OK FAIL on my part. At some point when I had the mono (sub) amp disconnected and I was playing with the settings, I set the 'input sensitivity' on the amp to "0.6V-2V", when it should have been at ".2V-.6V", for this reason, the subs were playing at less than half the volume they should have been. I just flipped the switch and got my subs back to full volume. Anyone have an idea how high I can set the amp's gain if it is 1550RMS clarion, and the subs are 12'' JBL 350RMS each (700RMS total)? right now I've got it at a little more than half gain. Also, best crossover frequency? right now it's halfway, think max on the dial reads like 360Hz. thanks guys!
  • Who's Online   0 Members, 0 Anonymous, 927 Guests (See full list)
