why did this happen?
i pulled out my alternator today and replaced it with the stock one. here is what i found.
the right side is the half connected to the battery, the left side is what was connected to the alt. these are 4awg, with 100amp fusing in between both
this is the OEM wire connecting to the alternator. my question is: is this wire still usable? looks burnt.
and what happened here? did my alternator have a short or something??? im not quite sure. all connections were secure and i wasnt abusing my alternator as far as my knowledge goes.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
ok first all, you need to fuse a 4 ga wire to 150 amps not 100, did you ground the alt also?? the reason i say 150 is that you didn't feed the alt enough juice from the battery, you limited the current so the alt was hungry and pulling for power so it burned up the cord excessive overheating for not getting enough juice. Check out the wires max fusing on the web, even 200 is ok, if you go 0 ga then you wanna fuse it with a 300
Umm...alts don't pull juice from the battery, it's the other way around.
Were your cables running by something hot on the engine? Exhaust or something?
Too many projects, too little time...
FAIL, and if the fuse didnt blow then 100A fuse will be ok.
:edit: check the wire, if the wire was "burned up" the coating would be melted on it too, which shows to small of wire. Which in that case, heat causes an increase in resistance, which would have made the fuse blow. Simple electrical knowledge there
My F-150 Build (So Far)
2 DC L3 10's
Kenwood KDC-X794
(4) Selenium ST200 (Highs)
(2) RE X8 (Mids)
Sundown Sub/Mid/High Amps
Shuriken Batteries
Knu Wiring
My Feedback Thread
wow @ speedball
as for the OP. there had to be some kind of short somewhere. 100 amp would have blown if the power was traveling through it. which makes me believe that something else started the arcing process
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
@speedball....seriously? Need to ground the alt? You mean like bolt it to the block? .......
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
u turd the alt is already grounded by the case being bolted to the engine lol
the fuses are fully intact. i figured keeping the stock wire and the 2 runs of 4awg would suffice for a 200 amp alternator. i had the big 3 done. everything was tight and secure. the wires going from alt to battery were close to the engine, but certainly not laying on it by any means. so is this problem a fault of mine? I've had this alternator for about 2 months now with no problems.
edit: and yes i had a wire going from a bolt located on the engine, there was already a OEM ground wire there so i figured it would be okay.
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
Haha I know....that's what I was sayin.
Systemless.
  • Who's Online   0 Members, 0 Anonymous, 876 Guests (See full list)
