regizzle Posted July 13, 2010 Report Posted July 13, 2010 OK SO. First off hello and thanks for viewing my post Heres what i have: 1998 Chevy Tahoe Stock Alternator Optima redtop Pioneer Headunit pioneer amp with 800RMS Mono block 2x 12" Kicker L7's(750 RMS each) Now, My questions. Can my current alternator put up with the draw from the subs? Being my amp is currently only putting out 800 rms being 400 rms each sub at 2ohms. Would i need to upgrade my current alternator for when i buy a kicker 1500.1 Amplifier? Should I wire up a 2nd battery? And if i do, Does it have to be an optima red top? or can it be any battery? Should i get a capacitor? and if i do, would it draw from my battery and kill my alternator in a negative way? ( dont want to from everything i've read ) I'm sure i have more questions. BUT, if anyone could answer my current ones, id be more than delighted Hell even donate some 1/0 wiring and a 1500.1 amp
speedball1978 Posted July 13, 2010 Report Posted July 13, 2010 get your second battery first, lose the cap, run 1/0 wires front to back run 300 anl fuses by your front battery and back battery, that way when you get your new amp you're all set as far as the alt, depends on how big your current is, amp wise... if its a 90 then upgrade it. and then you're done
speedball1978 Posted July 13, 2010 Report Posted July 13, 2010 make sure the battery is deep cycle, i would recommend xs power or kinetik or shuriken
regizzle Posted July 13, 2010 Author Report Posted July 13, 2010 Well im on a budget, My current batter for starting is a red top optima, By adding a 2nd battery could my second be a yellow top optima? ( yellow top is deep cycle ) also, my current alternator is 140AMP.
Jared420 Posted July 13, 2010 Report Posted July 13, 2010 get your second battery first, lose the cap, run 1/0 wires front to back run 300 anl fuses by your front battery and back battery, that way when you get your new amp you're all set as far as the alt, depends on how big your current is, amp wise... if its a 90 then upgrade it. and then you're done X2 Capacitors are damn near useless. From what I understand the only application a capacitor works in is if you have very very very little to no voltage drop and you just want the cap to have that extra bit of juice on the hard long notes. Try and findout what size stock alternator you have, in my 06 silverado I had a 120 amp alt stock, I upgraded to a high output but the 120 and my stock battery handled my aq 1200 just fine. I would get a second battery, does not have to be a redtop, if your going to stick with optima get a yellowtop for the back, if not go with whatever you want i would recommend getting a bigger battery just because youll have it already if you decide to go bigger. Id, do the big 3 in 1/0 gauge and 1/0 from front battery to 2nd battery. always fuse like speedball said. 2012 silverado ext cab ltz 24" kmc rims AudioQue 2200 Pioneer AppRadio Alpine mrx f35 4 channel Bose mids and highs Iraggi Alt + stock alt in a DC power dual alternator kit Yellowtop+stock under hood 0 gauge Knu wire Big 3 4 gauge stinger (4 chan wiring) 3 DC 10'' LVL3 with LVL4 parts
regizzle Posted July 13, 2010 Author Report Posted July 13, 2010 OK SO WHO HAS 1/0 WIRES LAYING AROUND
Jared420 Posted July 13, 2010 Report Posted July 13, 2010 Well im on a budget, My current batter for starting is a red top optima, By adding a 2nd battery could my second be a yellow top optima? ( yellow top is deep cycle ) also, my current alternator is 140AMP. With a 140 amp, red and yellowtop you should be able to handle 1500 rms with ease, Big 3 and some 1/0 gauge and your voltage should be sittin nice 2012 silverado ext cab ltz 24" kmc rims AudioQue 2200 Pioneer AppRadio Alpine mrx f35 4 channel Bose mids and highs Iraggi Alt + stock alt in a DC power dual alternator kit Yellowtop+stock under hood 0 gauge Knu wire Big 3 4 gauge stinger (4 chan wiring) 3 DC 10'' LVL3 with LVL4 parts
Jared420 Posted July 13, 2010 Report Posted July 13, 2010 OK SO WHO HAS 1/0 WIRES LAYING AROUND Look in the for sale section Im sure a bunch of people have some layin around. if not I got a good deal on ebay from knukonceptz wire, you shouldnt need that much just to do the big 3 and hook up a second battery. depending on where you plan to put the second battery 2012 silverado ext cab ltz 24" kmc rims AudioQue 2200 Pioneer AppRadio Alpine mrx f35 4 channel Bose mids and highs Iraggi Alt + stock alt in a DC power dual alternator kit Yellowtop+stock under hood 0 gauge Knu wire Big 3 4 gauge stinger (4 chan wiring) 3 DC 10'' LVL3 with LVL4 parts
regizzle Posted July 13, 2010 Author Report Posted July 13, 2010 Well at this time, i think i can only buy the 1/0 for the wiring to the amp and big 3. + what does it matter what fuse i put into the line? a 300A or 150A.
