Hello, as the title says I am wondering if someone would be kind enough to do a sketch up for me.
Box dimensions are: 50"W x 40"D x 24"H
Port is 30"W x 15"D x 8"H
its 6 15's in a subs up port back config. No need to add bracing or 45's.
Thanks to anyone willing to help me out.
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
I can do a solidworks for you if thats any use...
Live life to the full... Then TURN THAT BITCH UP!
heres the calculations..idk if you already did this but here anyway
2 18's Fi SSD All Options Dual 2 ohm
Rockford Fosgate T20001 Bd
1/0 gauge Knukonceptz power wire
Pioneer Touch Screen Navigation AVIC F700
13.62 cu ft box ..28 hz
250 amp alternator
2 kinetik 2000 batteries
Xs Vcm Module
ok I did it in solidworks but here ya go :)
1" thick wood
Edited by Spitfire2k6
Anyone else care to give it a shot? Thanks for everyone who has already helped out. I just want a couple other versions.
I am learning how exactly this box calc works. Where it says # of common port walls...if I used the bottom of the box as a port wall I would put a 1 here, correct?
d(-__-)b
Correct. If you are ever second guessing that part of the calculator, you can click "Help" at the top left of it, scroll all the way down, and it has links showing what to type in depending on your type of port.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
