I purchased a Hifonics 1606D for my car its a 97 Ford Escort. has a stock alternator and battery basically. I want to know if i can just upgrade to get a yellow top for just the sub and amp then later on upgrade the alternator. Also how much will these voltage drops harm my battery, sub, and amp? Anyway i can try and avoid it for now so i can save up to buy a new alternator and all that?
System:
18" MA Audio 1800XL (older one)
Box 4.14 cubes tuned at 32hz
Pioneer DEH-1900MP Dash Player
Hifonics BXI-1606D running at 2 ohms
Factory speakers other than the back which are scosche 5X7's
I don't think you should have too many voltage drops with a yellow top and stock battery with that amp, I think Accordman had an explorer maybe he'll respond to this.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Alright well i wont be getting a yellow top for a lil bit so yeah. Im sure my stock battery will being getting hit hard. Do you happen know how bad the voltage drops could be? My buddy is running an 18" FI SSD with a Crunch 1600.1 and he says his drop is like 10.7 volts or something with a red top battery just that tho.
System:
Yours will probably be similar, adding the yellow top wont help near as much as the alternator would. I have a second battery on mine and my voltage drops to around 10.5.
1999 Civic Si
Current setup - 147.5 db
Memphis Mojo 12
Memphis Mojo 2500
what does an escort have to do with an explorer?
btw, you should see ~10-11 volts. get an alt as soon as you can.
Yeah. How much would an Alternator for my car cost?
System:
do the big 3 in 1/0 and I bet you dont have nearly the problem you have now, along with a agp type batt you should be fine, I ran a AB 150.1 on 1 batt and stock alt and didnt have voltage drops like that, and I will garuntee that 1606 isnt nearly as powerfull as the 150.1
upgrade all your wire to 1/0 and then add a batt if your still having big voltage drops something is wrong.
my bad :blush: I speed red that, and thought it said explorer for some reason
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
Alright so just try the wiring first then if problems continue go up to a battery? Id buy an alternator and battery but yeah im a teenage kid buying all this myself so yeah kinda tough haha
System:
  • Who's Online   0 Members, 0 Anonymous, 303 Guests (See full list)
