DC Sound Lab
18" XL box design?
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
kind of looking for more detailed specs.
Everything you asked for is on that page. If you need to know something else, just ask..
Edit: Calculate Port Size
The box port can be calculated with a simple formula. Box volume in cubic feet X 16 (the amount of port area in square inches per cubic feet of box volume). For example, 3.4 cuft X 16 sqin= 54.5 square inches of port area. Try to stay within 10% of this number.
The port length should be 16 inches deep. This tunes the boxes to about 40 Hz.
Edited by Slawsen
00' Nissan Xterra
I have mine tuned to 32 Hz with a slot port at around 6.8 cubes. Off of ~2200 watts. I'm loving it right now. Hopefully the second one will be on it's way in a couple of months.
Are you going to be be for sure running the t4000?
SMD Super Seller/Buyer
Audison----Hertz----Rainbow
I have my two xl 18s in a 13cube box with 210sq in port tuned to 33hz off of 7000+ watts and its brutal actually hurts. waiting on two more 18s then it will sound good
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
yes, i have 2 t4000 that will be installed.
'00 Honda Civic Si IASCA stock trunk/pickup 1 World Record 4/20 150.6/150.7dB
Team DC Team XS Power
Team ISB
Steve's Body Shop
http://www.dcsoundlab.com/
let me know what it sounds like. what vehicle you putting it in?
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
