Nissan Pulsar Build Aussie Style
Here are some pics.
Final layer of resin on the pods.
A little somthing I grabbed on the bay. I have 2 more on the way.
Speakers in after all them layers. And my choice of sealing the trims off to the door propper.
Parts all sitting on the "new" door trim.
Parts fitted for trial fit on the door.
Door trim "trimmed" and pod sanded. Will cover the pods once I get more glue. Took a whole can to do the 2 trims.
I am going out soon to get onto finishing the doors and putting in the speaker amp and cleaning it all up. Will get more picture graphs as I do today and put em up some time.
Systems:
Fun Car:
Deck: Alpine CDA-9887
Front sounds: Alpine SPR-175A x2
Front power: RF T400.2 Benched at 265x2 rms @ 2ohm
Subs: RF T1 10 dual 4 Ohm x1
Sub power: RF R500.1
Box yet to be built.
All in a Mazda 323 Hatch in the cargo area only.
Daily hack:
Deck: Alpine CDA-9886
Front sounds: RF T152 5.25" coax x2
Front power: RF Power T400.2
Subs: Alpine SWR-1021d x4
Sub power: RF Power T20001
4.59cuft net 56" of port tuned to 32hz.
Work ute
Deck: Alpine iDA-X303
Speakers front: Stock
Speakers rear: None
Subs: Alpine type S SWS-1040
Amp: Alpine MRV-T320 x1 for woofer.
Box 1.42 cuft 39hz hidden under tray in blow thru design.
New ute to be much different.
nice work, new doors trims look great so far, will you paint/trim the factory plastic bits (handle and map pocket) to match the rest of it?
is the new door trim thicker/sturdyer than the old one? should help a lot with midbass :)
^^^ clicky pics for build logs ^^^
Well yeah I have dyed the plastics in matt black to blend in nice with the carpet. Came up a treat.
I unfortunatly got nothing done on my car today as a couple buddys came round to put the new punch 6.5's in the front of a cressida. That then went to a second amp install, Then to a new box. Got it all done in one day. Didn't get pics as we were on a mission to ge shit done propper. We were very impressed with the box designed on the torres calc. 3.5 cubes after disp with 54 cu in of port way too much port but it worked a treat tuned at 37hz for the 2 $100 kenwoods and 200 rms a piece. Gets plenty of air movement with the seats out. More on my car in the coming days. Sorry fellas.
Systems:
Fun Car:
Daily hack:
Work ute
Speakers rear: None
I managed to get off my backside and get somthing done tonight.
Got some door trims mounted up and wires run to the doors.
Mounted the first of 2 RF Prime R500.1's
Supprisingly there acctualy is room with the seats up.
Now for a couple of the amps.
Punch45 25 to life edition.
Prime R500.1
I will try not to be too lazy over the next couple days and get speakers in the doors and amp for them in. Then I better go strike a deal on a second amp for the subs as the 500.1 does a poor job of running 4 D2 ohm woofers to capacity with only one coil connected. Then I will just need to get another power cable for the second sub amp and 16 35mm long bolts, 32 nuts and 32 washers to use as terminals on the box. (i want to be able to swap and chance the load easily)
Systems:
Fun Car:
Daily hack:
Work ute
Speakers rear: None
Hey bro where in Tassie are you? PM me I dont see many guys down here doing much car audio. Nice to see another Tas guy on here! Build looks good, nice type arrrhhs!
I'm not an out of control driver, I'm completely in control.. only sideways..
-Nissan R32GTR running 213KW RB20DET on 14lbs of boost.
-Holden Commodore VY SS UTE running stock.
-Holden Rodeo mini truck project, soon to be running SR20 on 13lbs of boost.
-Landcruiser UTE running 1UZFE v8 11" Lift on 35" MT Classic II's wrapped in Cooper STTs.
^^ and the list goes on..
Hey cynner I am up in launnie. Hows the weather down that way? I have been about the traps not showing off much latley but up until 12mths ago I made sure if there was anything to do with boom I was all over it seeing what me or the mrs could win.
Systems:
Fun Car:
Daily hack:
Work ute
Speakers rear: None
Yeah man, that sounds good. I dont see many down here doing this type of work. I'm doing my project now. Temp system until I go to America and bring some things back. Once you get everything done I'd like to hear it. I've only really heard my own setup. No one comes close to it sadly..
Well I am now one step closer again.
Sub amps are both mounted now (yes I got the second one tonight) new one is just in the blank spot on the box in the above pic.
I made a new alt to batt cable as the factory one is only like 16ga. Now I have me some cable that looks about 4ga from the outside but has like 8ga inside. I did a double run to be sure crimped and soldered the ends with some old 8ga gold plated ring terminals that I had lying about. I have already done a 4ga engine to batt and 2 4ga chassis to batt cables. I am in the process of making a bracket for a second alt where the air con pump would be if fitted and some room for a seccond batt up front. This will require the movment of the coil washer bottle and some other crap that I will hit with a hammer once I remove it just cause I can.
I also found in my pile 3 stinger voltmeters that I bought on eBay for $14ea one will go in this project one in my other car and one is to go in a buddys Mitsubishi Mirage that I will be building in the near future :hairtrick:
Tomorow night I will be making some progress by soldering the front speaker wires on the speakers and fitting the doors off, mounting the x-overs and tweeters and hooking all together and to the amp. In the background of the pic of the rhs door my roll of cable can be seen 10ga rockford ftw...
I want to have the doors playing tomorow night ready to run the power to the sub amps on the weekend.
I will see how I go for motivation though....
Systems:
Fun Car:
Daily hack:
Work ute
Speakers rear: None
  • 3 months later...
Good news.
More parts have been secured for the snot box. I now have a Rockford power T-400.2 for the front doors and 2 pairs of T152's 5 1/4 coax. Will fit them all out later tonight and see if I can make more noise again. I may even slam the T2000.1 I have in the shed in there as the other car will no longer be getting woofers fitted as they make the car far too heavy.
Pics will be loaded up in the next few days.
Systems:
Fun Car:
Daily hack:
Work ute
Speakers rear: None
Pics of the new parts sitting on the bench at work. Will snap some installed pics later.
New stuff goes great. The new amp gets the speakers going with ease. Possibly a little too much power for them but that is always a good thing in this game.
Systems:
Fun Car:
Daily hack:
Work ute
Speakers rear: None
