Nissan Pulsar Build Aussie Style
Hey all I thought I might start up a Build log of my daily hack.
I previously had some equipment in here but that was about 3 years ago. Since then I have played about with different mids x-overs tweeters woofers amps and head units.
The local car audio shop had a big sale up to 70% off. I couldn't resist and I bought a few items.
I grabbed a RF T400.2 for my weekend car and a RF R500.1 For this project.
I already had a Punch45 (25 to life edition) sitting in the other car. Along with the woofers that I have had since the day they were released in Australia. The speakers being used I bought for $30 a pair at my local parts store (I keep a close eye on the clearance list).
I woke up saturday morning and I felt somewhat motivated. I went to the hardware shop and grabbed a sheet of MDF and a box of 1000 screws (45mm long) $62.50.
I have had a box in mind for some time so I went with that one modified slightly as I went. 39x23x13 were the final dimensions with 56" of port tuned to approx 34hz.
The car it will all be going in
The woofers
Timber sitting in the back of the car I will all go into.
Part way thru mock assy
Testing where I want to put the woofers.
Making sure the holes are cut correctly (fail) Far one don't go all the way in
Finaly after testing in on the test amp in the shed in the back of the car with some temp ghetto wiring.
The end result is amazing. Shame I won't be pulling any hairtricks running only 500wrms on the 4 woofers but it is loud.
I have already started on the front door pods today as I got the box done in one afternoon and had some timber left over. I will get more pics up once the glassing gets finished tonight as my mate (pro on the glassing) is on the way over to get the glass layed out. They are just a simple bolt up job but will get the job done.
Systems:
Fun Car:
Deck: Alpine CDA-9887
Front sounds: Alpine SPR-175A x2
Front power: RF T400.2 Benched at 265x2 rms @ 2ohm
Subs: RF T1 10 dual 4 Ohm x1
Sub power: RF R500.1
Box yet to be built.
All in a Mazda 323 Hatch in the cargo area only.
Daily hack:
Deck: Alpine CDA-9886
Front sounds: RF T152 5.25" coax x2
Front power: RF Power T400.2
Subs: Alpine SWR-1021d x4
Sub power: RF Power T20001
4.59cuft net 56" of port tuned to 32hz.
Work ute
Deck: Alpine iDA-X303
Speakers front: Stock
Speakers rear: None
Subs: Alpine type S SWS-1040
Amp: Alpine MRV-T320 x1 for woofer.
Box 1.42 cuft 39hz hidden under tray in blow thru design.
New ute to be much different.
The splits were 30 a pair. Subs I bought on the release date.
The door pods are near ready to test. one more layer of matting to go.
Pulsar is a 1986 N12
Systems:
Fun Car:
Daily hack:
Work ute
Speakers rear: None
Dope care with dope tranmission
lookin good, i did my first proper install in an N13 pulsar, 2 12s in the boot and dual 6.5s in the front, it went pretty good till i blew one of the subs as well as the head gasket :P
im keen to see how you went with the door pods :), also vids of subs :P
^^^ clicky pics for build logs ^^^
I will have to see if i can fin a cam that will get vids of the woofers. Unfortunatly on 500rms they are not the biggest movers about. Might have to through the T2000.1 in for a play. =@
Systems:
Fun Car:
Daily hack:
Work ute
Speakers rear: None
Well I am now part way thru the door pod builds. I have decided as the doors are just a simple flat panel that once the pods are made I will be screwing them to some new flat panels. I will run to the shop and grab some MDF tonight and start on the panels tonight. For now I have some progress pics of the pods.
The speakers that will be going.
Inside the box
In the rings I made. Not bad perfect fit first time. Not too bad for jigsaw work.
Factory trims witht the old pods. I will be glad to get rid of these.
The start of the pods. I routered the edges of the base plates so the glass sits nice and rounded as
these are designed to simply "bolt" in.
Starting to get the shapes and angles nice. Will require no cutting of the door metal.
All wrapped up ready for some resin.
First layer of resin layed on. Mate of mine that does this for me is great at getting it on there good and strong.
Systems:
Fun Car:
Daily hack:
Work ute
Speakers rear: None
Well pods are all but making noise now will upload some pics in the morning and get em up here before I go out and put the speaker amp in and get it all going.
Systems:
Fun Car:
Daily hack:
Work ute
Speakers rear: None
