having the speaker wire hooked up but disconnected from the subs is the same a just disconnecting the wires from the amp.
In the clamp test for the amps you have to have everything hooked up because its measuring the actual current output.
some amps like to fry if you play them with no speaker hooked up. how long were you testing?
Edited by fritosaregood
i rode around for the longest time with my saz1500d hooked up with no speaker.... never blew ;bullshit claim
well it has happened to some ppl.. you got lucky.
were your rcas hooked up?
some sundown amps like to fry if you play them with no speaker hooked up. how long were you testing?
just 10 seconds...like 3 times. after it went to protect i just stopped my ipod and turned off my car then back on it was good to go again
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
Well there's been a few warranty claim where people were running there amps all hooked up minus the speakers and POOF. Its because the amp is playing with no resistance and it goes poof. Maybe he's lucky and its going in to protect before it goes poof.
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
i think it already got said a few mins ago, but try it again with the speaker hooked up and see what happens
i will definitely try that in the morning. is that the only thing wrong that comes to mind or is there other things i should try too
been like that since the start. bass boost on amp is 0. GAIN REMOTE IS MAX because its not a bass boost remote its gain level.
i would turn down the gain. def don't have it turned up to max, could easily be the problem.
2000 2dr blazer
15" diamond audio d3
4 cubic ft. tuned @ 32hz (slot port, sub back, port back)
debating on a wall or no wall.
Shay-kee
the gain know only turns the gain up to as high as the actual amp is set at.
its not bass boost its basically an extension of the gain level at my fingertips and if i set the remote at minimum then set the amp then turn the remote up that negates the point of using the DMM. but to that note i will disconnect it before i do it again
  • Who's Online   0 Members, 0 Anonymous, 1440 Guests (See full list)
