Thanks. Yeah, more bracing and several layers of mat and fiberglass all the way around- threaded rod and stuff. Double layer on the baffle with a 3rd layer going on for aesthetics/amp rack. I have more pics of that, I just have to upload them and I don't have time just yet.
Much better! :)
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
And let there be pics:
Posted Image
Trying out the circle thing on a scrap piece of plywood
Posted Image
Works pretty good, and goes up to 50-some inch diameter cuts, all the way down to 8 or so (don't remember for sure, but I almost never work with 10s anyway).
Posted Image
Back of the box - first layer of the baffle glued and nailed down.
Posted Image
Screwed the 2nd layer in place so I could cut both holes at the same time and then clamp the layers togehter:
Posted Image
First hole, you can see the cutout diameter is 16.75, I went 1/16 of an inch over- I'm sure its ok :D
Posted Image
Posted Image
It's a pretty tight squeeze
Posted Image
3 of four
Posted Image
Finished and ready to attatch
tejcurrent
XS Power
T3
Posted Image
Top layer unscrewed to glue the first:
Posted Image
Posted Image
It's ready to take the 2nd layer.
Okay, glued, screwed, nailed, and clamped to sit overnight:
Posted Image
Posted Image
Heres the next morning, the layers are ready to go, just some fine sanding to clean things up
Posted Image
Ready for some threaded rod:
Posted Image
Posted Image
Port painted black
Posted Image
I drilled a 1/2" hole in the top, and a 1" hole in the bottom so I can bolt it easily
Then I'm using a small block with a 1/2" hole to let me flush mount the head of the nut
Posted Image
Posted Image
If you use a 1" bit like you'd find in a door-knob installation kit it fits perfectly without taking too much wood (that's where I took mine from).
Posted Image
Then I put the socket on the end of the rod (with nut on) just to center things nicely (and very easily).
tejcurrent
XS Power
T3
Fiero, I'll but using carpet I think. I've never seen a large box covered nicely in carpet, so I think I'll make it match the interior pretty well.
More pics:
Posted Image
Almost ready to screw/glue/nail in place, just tightening the nut up on both sides to help use that as a 'vice' to just keep it held firmly (but not so tight as to bend the box outward).
Posted Image
A picture of the bottom of the box with the nut now countersunk.
Posted Image
You can see all that's left is a small hole.
Posted Image
Glued in place and put a few nails in, later I added a few screws but I forget to get pics
Posted Image
Just wanted to say that this socketset is amazing. At lowes for around $30, it allows you to fit your socket over the longest bolts, or sparkplugs. Very handy, and works great in situations like this or removing benches in cars.
Posted Image
Finished rod, ready to bit trimmed.
Posted Image
Thank you Rigid- great battery powered sawzall, makes quick work of it.
Posted Image
Posted Image
3 layers of fiberglass over the bottom, especially that little block and where the bolt meets up with it.
tejcurrent
XS Power
T3
Finally, pics of all the equipment:
Posted Image
Posted Image
Posted Image
I know, my office isn't finished- I'm still painting, changing outlets, and I need to refinish the floor.
Posted Image
Okay, they look crooked but I just have two holes cut, all the work I got done last night :(
Posted Image
Port in place and painted a very flat black.
Posted Image
Interior, rod and all painted very flat black so you can't really see in there. I like it like that.
tejcurrent
XS Power
T3
OKAY! up to date as of today.
Posted Image
All 4 holes cut, beveling the edges with a 3/4 round over bit
Posted Image
Posted Image
Almost finished rounding over
Posted Image
Okay, sitting in place nice, I left about 1/8 inch all around- just sat a gasket there to show how it fits.
Posted Image
Dry fit a sub just to make sure there were no problems- it fits perfect
Posted Image
Okay, that's pretty much it- I have to put the bolts in the back for the terminals and carpet it, then it's ready to go.
The top plate (3rd layer) isn't really for the box, it's for the amps. It cleans up the look of it, hides the bolt, and makes the subs look recessed, but it's going to be part of the amp rack, so it has a purpose. More pics to come as I go, but that's it so far.
tejcurrent
XS Power
T3
WOW....nice lookin build bro, i dont know if its been stated or not but what kind of electrical do you have? those 4kw's are pretty hungry amps.....I would hate to see one of them fried....Awesome work so far bro.
Thanks, yeah, I was about to get 3-4 260a alts and a bracket from iraggi, but some expenses on our house (fixer-upper) have delayed that a bit. Trust me, I'm sure I'll be happy to keep the gain down for the time being.
I have 3 batteries in, I'll have 6 when I'm done too. It WILL be up to par, but for the next month or so it will be very anemic. :(
tejcurrent
XS Power
T3
