i have a 2001 expedition with the rear quarder vent windows (what clap like a fat strippers ass cheaks). but for my system i have two audio que hdc3 18s copper coils runnin off a audiopipe 30001d. i have knu konceps 0 gauge and a batt. the subs are in a 13ft3 box what is tuned to 37 hz with 211in2 of port area. subs up port back. it moves alot of stuff but dose not sound loud. my buddys two 15 l7 are louder and he is runnin them of a 5500 watt power acousik. but there in a tahoe.
Whip:2004 Ford Expedition
Headuint:Pioneer AVH-P4200DVD
Alt:MechMan 270 Amp
Big 3: Yes
Rear batts:2x Kinetik HC2400
Power Wire:carolprene 0/2 welding wire
Volt Meter:X Scorpion
Front stage:Kicker KS6502
Rear stage:Polk audio 6x8s
High Amp:Boston acoustic GT-4100
Sub stage:Audio Que HDC3 18s Copper Coils D2
Low Amp:Audiopipe AP30001D
Box:6ft3 96in2 34hz
146.8 dbs @ 35hz Sealed up
how do you have the AP wired? how do you have your gains set? what kind of voltage drop are you seeing? how far away from the rear hatch is your box?
Team_DC-Derrick's Youtube
Team DC Audio
is runnin at two ohms. like more then 3/4 of the up. 13.0 v drop it only sits at 14.08 v at ilde with everything off. 8 inchs
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
tried moving it towards your rear hatch to see if there is a difference?
Team DC Audio
:ehh:
i have it rilly dose not make a differance. is my box to small? or could it be the rear windows? i was thinkin the rear windows. because my frined has a tahoe with two 15 l7s and the truck has like no flex on the out side but is loud as hell on the inside.
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
is his box a prefab..?
2kwatts at 2ohm..you have something not set right if you don't think 2 aq 18s are louder than 2 L7s
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
it does make a difference... try moving it towards the back and see if it makes it louder
Team DC Audio
3kw at 2 ohms...
Team DC Audio
  • Who's Online   0 Members, 0 Anonymous, 1004 Guests (See full list)
