Would a bad ground cause this..
After a few seconds of playing music, my subs begin to make a constant "hummmmm" sound. It happens while playing music, and if I stop the music, it continues until I power off the amps. Any idea?
EDIT: ... I noticed my grounds are about 1 feet apart from each other on the chassis of the vehicle. I'm thinking this is the problem..
Ground to the same spot and see what happens. that could very well be the case. 2 minute fix.
Eclipse cd7000
or its the rcas. Rcas cause a lot of problems if theyre cheap, or run next to any power wire.
2006 Nissan Z Track.
My Feedback Thread
I have a good pair of RCA's going from the HU to the first amp, then a cheap pair going from amp1 to amp2. I'll ground both amps to the same spot, and replace those RCA's and see what happens. BRB
Probably solved. From troubleshooting, it was the ground loop. But the new RCA's are nice aswell. 8)
  • Who's Online   1 Member, 0 Anonymous, 1992 Guests (See full list)
