I started this build a few weeks ago on my fiance's 02 mustang convertible, I am about 90% done right now. I have the build up on another forum so i thought I would put it up on SMD and try a shot a SOTM for august. Setup consists of Pioneer dehp6800mp head unit, Rockford fosgate T15001bd on subs, T4004 on the highs, connected by a monster cable sub only RCA and stinger 4ch rca. Power Wire is Rockford 4 guage from the front interstate battery all the way back to a Kinetik KHC800 sencond battery in the trunk. Highs I'm running JBL GTO8608C 6x8 components in the front and JBL GTO608C 6.5" components in the rear. Subs consist of three Rockford Fosgate P310D2's. Also wired up a Big 3 aswell.
Edited by craracer05
2007 Scion Tc- T1500.1bdcp & t600.4, Three P3D212's Ported at 40hz, T2 6.5" Components, Rockford Marine 8" coax's. Kinetik khc1400 in back, Kicker 0 gauge
1999 Cherokee- Rockford Prime Amps 300.4 & 500.1,Big 3, Rockford 6.5"Comp.s and 6.5" 2ways, 2 12" P2's Ported basic winter beater
2002 Mustang Convt.-T1500.1bd & 400.4, 3 P3D210's IB, JBL components all the way around,Rockford 4 gauge, Big 3, Kinetik khc800 in back
New wires ran.
Panels cut.
Upper mounting flange.
Panels routed and mocked up.
Baffles all screwed and glued in used an angle finder to keep the faces at the same angle on each side.
Bottom face mount glued and stapled to the face screwed down into wooden floor.Used PL400 sub floor adhesice If you haven;t used it you should try it, it doesn't let go!!!!
Left side panel pressure fit in for the moment.
Right side.
i have done simlar builds like that in the past in my stang are u porting them into the back seat? if not your only going to get trunk rattling but it will hit and 3 will hit as much as 2 will due to air space. but if u port into car u will get more low bass instead of that spl bass. good luck with the build keep us posted
Thanks To VexProductions.com
Theres nothing to port its infinte baffle trunk is the box. Even with three tens the the left over trunk volume is bigger than the total Vas of the 3 subs, hence infinite baffle.
Cobra wheels on a V6? hmmmmm....
Remember its a chic's car, lol!
Always good to see Mustang builds. By the way, those are Saleen wheels, not Cobras ;)
You are correct 18x8 saleen knock offs.
  • Who's Online   0 Members, 0 Anonymous, 1054 Guests (See full list)
