XS Power
i have 500 amp of alternator a 220 and a 280 iraggi (waiting on trip bracket from dc to run 3)three runs of 0g from front xs2400 to back 3100s i have 3 0g grounds from each baterry to frame front and back and my amps put out 3500 watts at 11.9v into 1ohm. my question is should i run grounds from battery to battery or am i ok going straight to frame like im doing. dom at irragi says to do it the way im doing i just want my amps to put out the most power and have the most voltage. also is my battery combination sufficient i know u guys are going to say go more 3100s in the back but i dont have the space without going underneath the floor of my hoe and i dont have the budget to drop another 6 to 9 hundred on batterys thanks
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
try it and find out?
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
lol im going to thank. CAR audio is an addiction and im hooked.DAMN its nothing but money right
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
no im running two amps strapped at .7 they put out 3500plus each so 7000 plus i think im ok i ran it for a few days with one 3100 and my voltage never dropped below 12.6 full tilt the 3100 is a monster. my 4 svr 3000s would drop to 11.9 11.7
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
well i just hooked up my 3rd alternator and my 2400 up front and i have 2 3100s in the back voltage stays in high 13s cant wait to get my vcm next week. thanks nathan for great product. im definateley not afraid to step up from my 7000w to 15k. :trippy:
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Irragi hes got good product if you are willing to wait i was able to contact him through text last week on a alternator fixand he said heas doing alot of improvements to better serve us. DC is out of my budget .ive heard mechman is good too
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
mechman is INCREDIBLE. matt is awesome
