alright so yesterday i took out my system, was 2 12s on a "800" watt amp, had my meter set at 13.8
( i was useing a old ass volt meter to seem how much i was getting at the amp so i guessed 13.8 since it was right near 14)
so after taking all that out i hooked my meter up to my 4ch
kinda guessed which one was power and ground
then today i got my DMM so i set my meter correctly @ 13.6 at idle
now when i drive i never see it go over 13.8 it droped to about 12.7 with the amp off, then rose back up and down etc the whole time i was driving
i just dont get how i can have no drop with my sub amp but have tons with my 4ch?
could i have the power and ground reversed or something?
any help here?
btw stock alt, everlast batt
edit: i also just refused with 2 150 amp fuses, (2)4g in and (1)4g out, could that be the problem?
its a distro block i think, http://cgi.ebay.com/DUAL-MINI-MIDI-ANL-FUSE-HOLDER-AMP-INSTALL-0-2-4-GAUGE-/270612118367?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item3f01bd3b5f
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
You have to set the voltage on the volt meter? That makes no sense, sounds like a gay broken volt meter
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
its a stinger volt meter, and it was only droping to 13.4 when idle
You don't have to "set" the voltage on a stinger volt meter...so why'd you say you did?
00' Nissan Xterra
yeah you do...you know that knob if you take the front casing off, you know stick a screwdriver in and turn?
um yes you do.... when you take off the little black cover there is a blue and white adjustment screw to calibrate the volt meter...
YEP!
my guess is a bad regulator
i thought about it but how did it go bad when i switched it from one amp to another? would the 4ch draw more voltage for some odd reason?
  • Who's Online   0 Members, 0 Anonymous, 3472 Guests (See full list)
