deepsilencer's Walled 08 malibu LTZ (V.2)
Got any more pics of how you ran the power wire, im running wire this weekend in the same car 09 Malibu any pics would greatly help and been wondering the dimensions of your box so i can see how big of a enclosure i can fit in there, it will be 2 12" Xcons on a Soundstream Rubicon 2500d. Thanks.
the wire went through the driver side,
towards the driver's door hinge
and inside where the hinge is at there's a black pre made facotry hole already made for you covered on a really thin plastic
you can push that with you finger and if you have fat hands u can push it with a flat head
once your done doing that
you are going to be able to run 0 gauge through that hole,
allows you to run only 3-0gauge runs.
you can remove the door for easier access but i wouldnt recommend it
never ends up mounting the same.
any ways once you got that hole out of the way
you start taking the plastic trim by your door
and the one that is by your hood's pulley
once both are removed it would be much easier to have access to get the 0 gauge wire through the other side when you put in the wire through the hole
and there easy cake
once you got all the runs you need 2 or 3
you can use that purple/gray/pink insulation that is inside where that door's hinge is at to cover the wires
and once that is done it would look like if nothing ever went through there
and if you want to run more you can do the same thing on the passenger side but you would loose 5ft+ running it across the hood to get ALL the wire over to the other side
you can do what n8 did
cut through the firewall
its harder but it can be done
goodluck and if you still dont get me
i can take pics after work which it should be around 4.30pm
and my box dimensions are
13.5ht____32w____30d
Silencer could you get me some pics of the wiring into the door hinge area im looking at that area on my car and am confused still thanks.
I drilled two holes owith a unibit and ran it that way in mine.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Sorry guys N8ball and silencer disregard the above post. Been busy getting my wire ran and amp up and running, i found the easy wire run silencer talked about. Already to far in depth to repeat my build log, posted info took some pics etc still not done, but all i lack it the enclosure expect to have this setup up and running very soon. Have a look.
http://www.soundsolutionsaudio.com/forum/topic/47104-official-start-of-the-2009-malibu-build/
sorry bro,
i barely check this thread lol
just encase if i don't give you a fast response text me
TEAM FLEX ISSUES,TEAM DC AUDIO
2000 Silverado Ext 1500 v.3
(Walled Silverado)
4 DC Power 270a Alts on A DC Power Quad Alt Bracket
XS Power VCM,Stinger Volt Meters
4 AA Mayhem 18s
2 DC Audio 9.0ks Strapped
1 DC Audio 175.4
4 Selenium 6.5s & 4 Selenium 8s
4 Selenium Super Tweeter st350s
72 SQ Ft Of Stinger Roadkill Expert
Alpine CDA 9887
XS Power d3400(Hood),6 XS Power d3100s(Bed)
& much more.....
2011 Meca CA State Champion & State Record Holder In M5
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
i have a 08 malibu ltz....i cut out the rear decc so the subs are firing thru the rear decc...i have 2 12.2 orion hccas in a custom box..i got pics if u want for ideas
post them chevyon28z :drinks:
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
dont kno how to post pics but ima put my cardomain link
where's the link lol
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
your putting in two AQ;s in the malibu?
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
  • Who's Online   0 Members, 0 Anonymous, 1912 Guests (See full list)
