Best low pass setting for my system.
check it out....this is what i dug up for ya...on the bottom right hand corner of the headunit should be an audio button...you should be able to get to the lowpass filter from there...the lowest it goes on that headunit is 100hz...also that head unit is designed with one set of rca's out right? if so, it's sending a full range stereo signal to your amp that's why your hearing voices and yes i agree that it seems like the filter is bad on your amp which isnt filtering out the voices...you might be able to turn the rca's out to subwoofer out with that headunit...look under function top right button, the option might be there...use the up down right and left arrows to try to adjust these things....also try the eq button it might be under that....best of luck..
If that doesn't work, I think this will. It isn't feature filled, but I think it would meet all your needs.
http://www.amazon.co...1149634&sr=1-17
I have just about everything I need already here. I may end up running this old 4 channel in 3 channel mode and doing a small system in my room.
Thanks for giving me ideas Rebel... >_> lol
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
here is all my options under audio.
http://www.youtube.com/watch?v=OZ27qfmbI90
Just uploaded please let it process.
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
Found the filter it was at 100 its now 40.
What it says is F- 40-160 and then there is Q-2W
What is this?
Wow gives me the option for 1k and 10k EQ too!
EDIT: Found the specs of my HU
# Supertuner III™
# 24-Station/6-Button (18FM/6AM) Presets
# BSM (Best Stations Memory)
# AGC (Automatic Gain Control) for Optimum CD Tracking Performance
# Playback Compatible with Digital Audio CD-R (when Disc is Finalized)
# MOSFET45 (45Wx4-Channel High Power)
# RCA Preouts (x1 pair) (Front) (2V)
# EEQ Performance Chip
* 3-Band Parametric Equalizer
* Easy EQ (EEQ) switches 5 Factory, 1 User EQ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom)
* Source Custom EQ Memory (independent custom memory for each source)
* Selectable Loudness Control (Low/Mid/High/Off)
* Selectable FIE (Front Image Enhancer) (Rear LPF 100/160/250Hz)
What is this?
# Supertuner III™
sorry it took so long to get back at ya...where it says fie off...try turning it on......it should give you the choice for the lowpass filter there...also what you asked about the f and the q....the f and the numbers after it means f=frequency and the 40-160 is 40 hz-160hz....now the q is the width of the parametric eq...w means width....usually it will be w1/12/narrow1/narrow2/etc. pretty much it stretches out the frequency range or pushes it together....3-band eq will give you three ranges to play narrowing or stretching the range from low to mid to high...i would def. take that amp back though...
Thanks for the detailed reply! And also i commented on that guys video above and he said he hears vocals through his sub too.
His LPF is 50.
  • Who's Online   0 Members, 0 Anonymous, 2891 Guests (See full list)
