three speakers eight ohms
ok so i have a pair of floor speakers each with a tweeter and midrange and a subwoofer. it says each floor speaker has an 8 ohm impedance(the speakers themselves do not say what ohms they are). i want to replace them but im not sure how to keep the 8 ohm impedance with three speakers. also i think there is a crossover inside not sure how thats relevant. any advice would be appreciated.
http://www.the12volt.com/caraudio/boxcalcs.asp#par use the series and parallel calculator on this site. wire the first 2 speakers in series to get a 16 ohm load and then take that 16 ohm load and enter it into the parallel calculator with a 8 ohm load for the 3rd speaker and you should get a 5.33333 ohm load which if you are using a home theater amp or pro audio amp even though HT amps say 8 ohms most can handle down to 4 ohms but a 5 ohm load will do just fine on a HT amp so it doesn't have to be 8 ohms all the time.
My Car Audio Setup:
Sub: 1 RE Audio HC 15 Dual 2 ohm(soon to get a psi recone)
Daily Sub Box: 1.62 cubes net with 2 dayton audio 8 inch passive radiators tuned to 34.35 hz, 141.9 @ 48 hz sealed on the dash with termlab
Competition Sub Box: 3.10 cubic ft. net tuned to 50.58 hz with 2 6 inch aeroports, 147.9 @ 62 hz sealed on the dash with termlab
Amp: Powerbass ASA 1000.1 Dx(eventually gonna get a planet audio bb2400.1)
Big 3: Phoenix Gold 1/0 Gauge
Amp Wire: Knukoncepts 1/0 gauge
Alternator: Stock 90 amp
Battery Under the hood: Autocraft Gold Top Battery
Battery In Back: None for now but I am looking for one so pm me if you have one for sale
HU: Pioneer DEH-2900MP
Front/Rear Amp: Hifonics Txi-4408 4 channel amp
Front Speakers: Orion Cobalt 6.5 coaxial
Rear Deck Speakers: Orion Cobalt 6x9 coaxial
Home Audio Setup:
Speakers:2 Cerwin Vega D-3's (10" Woofer,5 1/4" mid-range,1" Bullet Dome Tweeter)
2 Cerwin Vega D-5's (12" Directed Audio Xtreme 124SX Subwoofer,5 1/4 mid-range,1" Bullet Dome Tweeter)Kenwood center channel and rears.
Amp: 2 Kenwood KM-105's from 1985
Receiver: JVC RX-6008V 5.1 Channel Receiver
Pre-Amp: Kenwood KC-993
Sub: still looking for one thinking about getting a 18 or 15 for my sub to hit the lows if anyone has one pm me
I do free box designs if anyone is interested
a lot of home audio speakers come as a 6ohm imp so if you get 3 of those wire two in parallel and wire that into series with the third to get a 9 :)
Live life to the full... Then TURN THAT BITCH UP!
over 9000 milliohms?
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
the cross over is what makes it 8ohm, cause every 3way floor speaker ive had each speaker was raited 4ohm, or 8ohm
i have a speaker selector that for some reason no matter how many speakers i got hooked to it does not change the ohm load comeing from reciever
its a wierd thing how these things work tho, i wanna build me some bookshelf speakers for the workshop and im gunna use the ones from this site
http://www.parts-express.com/speakers.cfm
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
aight thanks :) but what about the crossovers?
that site sells cross overs also so if u want to just replace it all then thats cool too, could even replace the terminal cup n what knot n just go from scratch :)
3x 2 or 3ohm in series,
3x 16ohm in parallel.
Running two driver series then a third parallel will result in slight phasing issues.
Hammerdown... 1%
