ok so i was hookin up my frends sub. everythin is hooked up right, least im pretty sure it is. when i turned on the amp the sub was barely movin. even turnin up the gain it still wasnt movin that much. wat could it be?? the amp turns on and everythin. idk wat i did wrong ha. at first i thought it was the terminals on the box but i hooked it up straight to the sub and the same problem happened. please help
thats happened to me before and it was the amp... it was broken or something and i got just a squeek of sound out of the subs, but i wouldnt give up on trying...
I've also had the subs not work at all cause my rca outputs were screwed up coming out of the HU
My First Build on SMD (Blow Through)
2004 Ford F-350 SD Lariat
Pioneer 3200BT DVD Deck
Infinity Reference Components not powered
Bully Dog Gauge Cluster Pyro, Turbo, Trans
SF3 SCT Tuner W/Customs
If you can't Join em' Crush em'
ah man but it was workin perfectly fine in my car. dam this pisses me off ha
Try it in a different vehicle bro if you can then you forsure know.
well i had it in my car for a while and it was workin fine. when my frend bought it i took it outa my car and into hers. ill check up on it again later cuz she had to go to work
If it don't work there's only so many things it could be. IMO it will work or it won't :) if the amp works in a different car then it could be a number of things but it's a process you gotta do :P
check how you got your subs wired as well, you could have it wired at a higher ohmload than you think
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
i got it workin :) idk wat it was but it seemed like the amp had to be on for a while like it had to charge up or somethin idk it was weird lol and the sub is a single voice coil 4 ohms and it was hooked to a 2ch bridged amp at 4 ohms. thanks everyone
