2 Sundown SA-8s in a Prelude
Nice build... Hope you get your trunk fixed.. all you need is water to ruin your whole build :/
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
more box pics
from the back
moved the wires because of fitment issues
thats better
fuse box out
glued together need to get more glue to finish up
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
Video isnt working man. Atleast for me it isnt.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
wheres your deadening at?
R.I.P!
(Nov-29-2009)
92 explorer
current build
the stuff i ha back there didnt turn out like i wanted it to so i pulled it all out
how do i get the bolts to stay still while i tighten then from the outside
Ive always had a friend or something hold one tight with a wrench while i get it from the other side.
'01 Honda Accord EX 4 Cyl4/18/13
Started new build
Headunit: JVC kdx250bt
Sub Amp: Hifonics Hifi 2000d
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Wire: Knu 1/0 and 4awg
Big3:
for the first sub that would work but when i get the second in there would be no way to reach around i might end up drilling all the holes and putting glue in them then putting the bolts in and tightening them down without the subs in so that way the bolts would be permanent and when i want to put the subs in i just take the nuts off and im good to go
