flashlight_65 Posted August 8, 2010 Report Posted August 8, 2010 I plan on running 4 aq3500's in the future but 2 for now my question is do I set them both to master and y split them to my 3sixty and then use 4 y splitters when I get the other amps or can I set one as the master and the rest as slaves gain match them and use the outputs for the inputs of the other amps? It'll be one amp per sub. Sorry for being confusing My builds: my caddy my 'hoe friends impala
flashlight_65 Posted August 9, 2010 Author Report Posted August 9, 2010 If I had to use 4 y-splits would it create a lot of interference My builds: my caddy my 'hoe friends impala
UnderLoK Posted August 9, 2010 Report Posted August 9, 2010 I don't know the details on this amp, but generally when you see a socket of some sort for the master/slave relationship that cable carries the signal as well as takes care of gain matching (in the master/slave). If at first you do not succeed, you are doing it wrong! -ARSCheck out my walled TBSS build over here4 Fi Team 18s on 2 Cactus K9 DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500 Pioneer X8500 6 XS Power D7500, 1 3400S Second Skin 2 270a Mechman Alts
flashlight_65 Posted August 10, 2010 Author Report Posted August 10, 2010 That's what I thought, when I called tech support at aq they told me in order to run 1 amp per sub each amp would have to be set to master and each amp would need it's own imput. If this is the case that's a lot of extra y-splitters and rcas unless I understood wrong. My builds: my caddy my 'hoe friends impala
UnderLoK Posted August 10, 2010 Report Posted August 10, 2010 That's what I thought, when I called tech support at aq they told me in order to run 1 amp per sub each amp would have to be set to master and each amp would need it's own imput. If this is the case that's a lot of extra y-splitters and rcas unless I understood wrong. I think they are high... I had a question about the 3500 and when I asked they spent about 100 words explaining the electrical I would need and didn't answer my question... haha I run 2 XXX's strapped. All you do is setup the subs in a 2ohm load. Take positive sub to positive MASTER then negative sub to positive SLAVE then run a cable from negative MASTER to negative SLAVE. After that just run their cable between the amps and double check that the MASTER/SLAVE switch is set correctly and hook your bass knob to MASTER as well as adjust the settings on the master (again the AQ could be a little different but that is normally how it works). How many subs that are hooked to the amp doesn't matter, amps just care about the load, at least from what I know... TBH I really should have gotten 2 of those AQ's instead but I got a killer deal which while cheap, I want more power now Oh well... If at first you do not succeed, you are doing it wrong! -ARSCheck out my walled TBSS build over here4 Fi Team 18s on 2 Cactus K9 DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500 Pioneer X8500 6 XS Power D7500, 1 3400S Second Skin 2 270a Mechman Alts
REaudioBuff Posted August 12, 2010 Report Posted August 12, 2010 if there is a switch on the amp for slave/master then put one on master and you should be able to like daisy chain the others after that and they should all be equal on gains. Using the other y splitters would more than likely cause a decent amount of noise. 1 Crossfire XS v2 15" 2 Deka group31a's 1 XS Power D3400 (under hood) 1 Addictive Audio 500.1 1 Rockford 3sixty.2 4 Crescendo pwx 6.5s 2 Pyle Pro Super tweets 1 Crescendo 1000c4 Kenwood excelon x494 Head unit Big Three upgrade All 0 gauge of course 1 4.56c^ft box @28hz (New Best official db score= 151.2 @ 36hz)
