DJ JDub Posted August 9, 2010 Report Posted August 9, 2010 Do i really need the fuse between my battery and my amp?? i know this is probably a stupid question but i was just wondering if it is actually needed.
David711 Posted August 9, 2010 Report Posted August 9, 2010 If you want to burn your car or truck to the ground then i wouldnt but if you dont want to then id put a fuse in. "WHOEVER SAID MONEY CAN'T BUY HAPPINESS MUST OF BEEN BROKE"
jhmeg2 Posted November 29, 2010 Report Posted November 29, 2010 Yes!!! you need a fuse. ////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
LT.Smoke Posted November 29, 2010 Report Posted November 29, 2010 Yes definitely use a fuse. For one thing its a smart idea and 2 if you plan to compete you will ahve to have one Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
Guest Posted November 29, 2010 Report Posted November 29, 2010 If you want to burn your car or truck to the ground then i wouldnt but if you dont want to then id put a fuse in. you are implying the vehicle will spontaneously combust as soon as the wire touches the battery/amp. he will be fine running no fuse, but for safety reasons, you should run a fuse.
