whatttt? didnt know you cant ground amp to battery neg?? ive done this on 3 setups and NEVER had an issue??
well you could ground it to the battery, but just not safe... you want to ground them to common ground...if the amps were to short out, the whole current would fall back to the battery.. not a good thing but if you run it to a common ground such a the chassis you won't be shorting anything out besides the amps...
It's fine...
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
2 270a Mechman Alts
