whatttt? didnt know you cant ground amp to battery neg?? ive done this on 3 setups and NEVER had an issue??
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
well you could ground it to the battery, but just not safe... you want to ground them to common ground...if the amps were to short out, the whole current would fall back to the battery.. not a good thing but if you run it to a common ground such a the chassis you won't be shorting anything out besides the amps...
It's fine...
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
  • Who's Online   0 Members, 0 Anonymous, 3079 Guests (See full list)
