kirill007 Posted August 11, 2010 Report Posted August 11, 2010 2ohms headunit goes to 35 i was at 25 when testing. All bass,treble,mid was on 0 Loud off etc Put subwoofer level on +15 if u set the gains. Thinking is the root of all problems... You ALWAYS get what you pay for.
jazz5000 Posted August 11, 2010 Author Report Posted August 11, 2010 Put subwoofer level on +15 if u set the gains. Max bass level on hu is +8 I thought all eq were ment to be off? Also what about loud setting? Thanks
Rebel4055 Posted August 11, 2010 Report Posted August 11, 2010 Max bass level on hu is +8 I thought all eq were ment to be off? Also what about loud setting? Thanks Put the sub to it's max setting leave everything else at 0 or off. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
jazz5000 Posted August 11, 2010 Author Report Posted August 11, 2010 Ok will try that in the morning. So 37.42v is what i should be aiming for. What about low pass filters etc? On the headunit the rca for the sub is s/w rear and rca for components is on front. Would it better to just run one rca from front and use amp output to input?
Rebel4055 Posted August 11, 2010 Report Posted August 11, 2010 Ok will try that in the morning. So 37.42v is what i should be aiming for. What about low pass filters etc? On the headunit the rca for the sub is s/w rear and rca for components is on front. Would it better to just run one rca from front and use amp output to input? Low pass should be around 8O. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
kirill007 Posted August 11, 2010 Report Posted August 11, 2010 Max bass level on hu is +8 I thought all eq were ment to be off? Also what about loud setting? Thanks No i mean subwoofer level, not bass EQ. Look in you're manuel for it. Thinking is the root of all problems... You ALWAYS get what you pay for.
jazz5000 Posted August 11, 2010 Author Report Posted August 11, 2010 Looked in manual still not sure, Do you mean on bass knob? I dont have one.
Rebel4055 Posted August 11, 2010 Report Posted August 11, 2010 Looked in manual still not sure, Do you mean on bass knob? I dont have one. On any deck you can control the level of the sub like on my friends kenwood it goes from 0 to +15 to -15. If it's on -15 is basically off and +15 is all the way on. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
jazz5000 Posted August 11, 2010 Author Report Posted August 11, 2010 oh ok. will have a look in the morning, edit: Just had a look in the manual and this is possible, so once i set to +15 and set the gains, What should i change to after? Also i assume then bass,mids,treble should be set to 0.
Rebel4055 Posted August 11, 2010 Report Posted August 11, 2010 oh ok. will have a look in the morning, edit: Just had a look in the manual and this is possible, so once i set to +15 and set the gains, What should i change to after? Also i assume then bass,mids,treble should be set to 0. After that just adjust your treble and such back to your liking. And yes leave everything at 0 except the sub level +15 Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
