There´s something called impedance rise wich is a bitch!!! Also, voltage drops, so after you start with 1000 watts you´ll see 500 watts at the most if you are a "noob" as you claim you are, wich i don´t think by the way!!! You have small power and that allows you to build a much bigger box, 1.6 per sub is kind of a burp box with tons of power haha.
Like orion said, i would get 10 cubic feet after displacement, subs up/port back with a 35 hz tuning, that should play very nice lows :yahoo:
common chamber, i would just sell those amps and buy a single one for the subs, much easier to fit on any space, less wires, etc etc, i would get 2 8" aeroports for that box :popcorn:
8" Aero ports, good call.
Thank you, glad we are on the same path :)
I can do 38" high (max), 50" wide(max) and the depth is as deep as I want
Damn, that´s big!!! Well, recommending something very fast because i have to go, i would get 19" H x 48W x 28D with 2 Aeroports about 13" long, that would give you around 10 cubic feet after displacement with a 35 hz tuning, this is using 1" thick MDF...
  • Who's Online   0 Members, 0 Anonymous, 1128 Guests (See full list)
