ok first ill be honest i dont know shit about cars but i need help with mine hopefully someone can help me out yesterday the problem started i would start my car it would rev a lil and then shut off it would do this several times tried to go to work and had to drive home because it would make this chugging motion almost reving then back to normal then reving again an when i drive it still does that chugging motion and several times on the highway would totally kill i am almost certain its the tranny when i checked the fluid it was a little dark an smelled funny but maybe that is from the hot engine it does have the original tranny fluid in it its a 99 monte carlo with the 3.8 in it its got about 143000 miles on it so any idea on what is wrong i know i gotta change the fluid but is it possible that the tranny is going bad any info would be greatly accepted
sounds like a bad maf sensor or tps you can rent a scanner that will plug into the dianostic port and give you the codes to see what the hell is goin on
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
that happend to my friends car it was the catalytic conveter and happend to another friends car and she had to take the motor apart and clean out the intake, otherwise id drain the tranny fluid and put new fluid in other than that im not sure i dont know alot about those cars
Current system:Front stage: Alpine type s 6.5No rear:Alpine type s 6.5headunit: alpineAmp: Jbl bp600.1
Sub: Alpine type x 12
dont know much about them. Found a "FLUX" Capacitor on ebay. If I add this to my system, can I really travel into the future? And how far into the future? That probably all depends on how I ground it though, right?
Dude dont even waste your money on capacitors get a second car battery preferably a kinetik or stinger or any other car audio battery use the battery that is correct for your systems true rms wattage do some research on the net for this. Go to kinetiks website they explain how to pick a battery from thier site that fits your system. :shrug:
yes i totally forgot about that might want to have the catalytic converter checked as well
big 3 1/0
yeah the guy i take my car to is great at what he does and for a dam good price im gonna have him go over every square inch an check everything to find out what is wrong
Orealy? Then why do you have this problem now? Why would you never change the tranny fluid in 11 years and over 140000 miles? You gotta take care of your shit, man.
SMD Super Seller
My Feedback Thread
x2 man this is what not doing regular maintenance results on ur car ..
is ur check engine light on? and it can be the cat converter and it can be somewhat clogged and not letting ur exhaust out
my brother's 99 monte carlo z34 had a similar problem. when warm, you would drive it and it would stutter and kick. flooring it would cause it to kick like no other and the CEL would go on, code p0102 saying something about low voltage in the maf/vacuum circuit. it was the mass air flow sensor. he replaced that and it was fine afterwards.
yea i know i should have done a better job of takeing care of it an paying for it now but iv got other cars to use and this one im not to worried about its at the shop now getting the total over haul everything is getting checked
  • Who's Online   0 Members, 0 Anonymous, 2192 Guests (See full list)
