need receiver help
i just bought a used sony receiver and hooked up a couple of floor speakers to it and whenever i play something there are subtle volume fluctuations. anyone know why?
Since i own a sony (str-db840) surround sound, i figured id help with what i learned from mine... First off....
1.) Are you playing sound through dolby digital? or is it a stereo source like an ipod, radio, cd player, or something else like that?
2.) check to see if your receiver has a "dynamic range" setting, if it does, put it to max. it will hold back a ton of random moments when the tv volume will just blast you out of your pants.
3.) check to see what your surround speakers are set to. sometimes if the gain is set too high on them, everything you listen to that has jumps in the volume will sound as loud as a rocket taking off.
4.) if you are not using all of the 5.1 (or maybe yours is a 7.1) surround sound system, i would disable the channels you have nothing hooked up to. because the point is to have all the speakers going up and down in volume to over-ride the voices and everything.
5.) if the random volume raises happen when watching tv, there isnt any 100% way to make it disappear. even if you have a million doller home theater system, it will still manage to work its way through from the a-holes who make the commercials at louder levels. so dont think you can get everything at one level, you will be able to get pretty close to it but not all the way.
Any questions dont hesistate to ask.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
are the speakers wired at an ohm load that is safe for the receiver?
good call Kranny, i forgot about that since i installed my unit 4 years ago. My unit is nice from the external impedance selector so should you change it, just flip the switch.
