Incin Posted August 14, 2010 Report Posted August 14, 2010 How can I get the most out of the amp without having to get two more subs because I dont have any money to do that. And ill admit I dont really know alot about setting up car audio so it doesnt affend me if you call me noob or whatever. well, it'll make you shit bricks.
Autruche Posted August 14, 2010 Report Posted August 14, 2010 Need more info, what subs, dual voice coil or not? what coil impedance? what amp? rms for both? Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
Incin Posted August 14, 2010 Author Report Posted August 14, 2010 The amp is a Boss Audio CX650 Chaos Exxtreme, the subs are 2 RF P1s there 4 OHM an I think its once coil, rms for the RFs are 150 an the amp is 100x4 at 4 ohm well, it'll make you shit bricks.
Autruche Posted August 14, 2010 Report Posted August 14, 2010 I would say bridge one sub to the front channels and bridge the other to the rear channels and set your gains reasonably with a DMM. Just know that amp probably won't do rated but with each sub bridged it should power those just fine. Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
Incin Posted August 14, 2010 Author Report Posted August 14, 2010 the amp is rated 500 max x2 4ohm bridged. An i kn ppl tell me that max power dont matter well, it'll make you shit bricks.
Autruche Posted August 14, 2010 Report Posted August 14, 2010 Bridged is always twice of what it says the rms is for each channel at 2 ohms, because when you bridge an amp each channel sees half the overall impedance. so 4 ohms bridged is the same as 2 ohms to each channel. That amp will probably do about 200-250 watts rms bridged. and putting 200 into those subs should be fine, but I don't have any experience with them, but I still think bridging both subs will be fine if you set your gains right. I've done it this way before and it worked fine with a 4 channel. Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
R_Mac_1 Posted August 14, 2010 Report Posted August 14, 2010 Yes just make sure you match the gains on the two subs (especially if they are in a box with a common chamber). You can use a DMM to match the gains. 2002 Pontiac Bonneville SSEi Pioneer DEH-P6000UB Alpine SPX-17REF 6.5" components (active) Sundown SAX-50.4 Sundown z15 (3 cubes @ 35 hz) Sundown SAX-1200D 2006 Buick Rainier CXL AWD V8 Stock Bose system 12" Alpine Type E in aeroported box Profile AP1000M
