thebull1tt Posted August 14, 2010 Report Posted August 14, 2010 I'm in the market for a new 12" SQ sub intended for a sealed enclosure that can handle 1500 watts RMS. Right now, I have my sights on either the Fi Q, SSA XCON, or RE XXX (54mm Xmax!). I'm having a tough time deciding on which sub to go with. My last sub, an old Image Dynamics IDMAX12V2D2 blew the tinsel leads right through the spider. Please help! Has anyone actually tried any of these subs? What did you think? Thanks for your time! '94 Honda Accord EX coupe (may be getting an '04 Accord EX coupe soon): Iraggi 200 amp Amputator alternator Alumapro 15 farad CAP 1/0 Knukoncepts wire throughout w/the Big 3 underhood 10 gauge speaker wire Q-Logic kick panels Scosche HEXAD RCA's XS Power D6500 (2nd battery) Die Hard Platinum AGM battery (main battery) 4 Horizontal Fans 144 sq. ft. Dynamat Extreme Dynaxorb panels inside the doors behind the mid bass Eclipse CD-7200mkII w/IPC-106 iPod module Precision Power A600.2 (2) (150x2 @ 4 ohms)w/Power Class adapters Precision Power A1200.2 (1200 watts @ 4 ohms bridged) w/ Power Class adapters CDT ES-01 tweets, ES-02 mids (both PSS spec) CDT PSS 6iM midbass CDT MX-1000 passive crossovers Image Dynamics IDMAX12 in 1.3 cu.ft. sealed
Socky Posted August 14, 2010 Report Posted August 14, 2010 I would say the SSA Xcon, they are rated at 1750rms, therefore they will last forever with a clean signal of 1500rms. Plus if you wanted it could handle more power and its cheaper than the XXX. Stronger than the Fi Q. Just my opinion. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
infinity Posted August 14, 2010 Report Posted August 14, 2010 im thinking the FI Q because it is made for quality It can easily handle 1500rms...Just get the cooling option. And since your using a sealed box, get high QTS. That means that you can use it for sealed enclosures.
BTL FTW Posted August 16, 2010 Report Posted August 16, 2010 a RE XXX 12 will slam and sound amazing if your build is up to par and you have the wallet for it Alpine F1 Status DD CS6.5 x2 Front Stage DD 9512H DD M4a @ 2 ohm DD S2b @ 8 ohm per channel I run high ohn loads for MASSIVE headroom and cleaner SQ 270amp alt D2400 up front D3100 x2 batter in back
notorious97200 Posted August 16, 2010 Report Posted August 16, 2010 Get the Xcon. You will love it sealed, or ported. I run mine in a 2.9 cu ft sealed box on a sundown saz 1500, and It is incredible. So much clarity, and output. The fi Q is a good driver, like the Icon( xcon's little brother). Can't compare to the Xcon. The xxx is way to expensive ! IMO I don't have that kind of money for a single sub. Be careful with the gain, you can burn another sub. even if the xcon is built like a tank! black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
