AQ HDC3 - 2 12's or 1 15" + Middle port questions
I'm working on selling my stuff and upgrading to some AQ HDC3 subwoofers. I believe I have the choice of either two 12's or a single 15. I want the loudest system possible while still conserving trunk space in a 2001 Grand Prix. The widest box I can fit in ATM is about 36", heightwise between 16" & 18" (if I play around with the 6x9's), & my main aim is to have a port firing out the back of the box into the cabin through the middle seat door. What would be the best way to go about at this, as I will be ordering this week.
POTATO!
Subs, sealed off, firing into the cabin is the loudest setup for a "trunk car". Might want to look into that as a real option first. Thorshammer is a great example of how loud you can get.
But to your question, I think you could fit 2 - 15's in the trunk (depending on the subs)...but I don't think it would be wise, as you'd likely have to build in the trunk, and not have very much room for anything else (amps, batteries, fuses and access to them).
2 12's, or 1 18" should not be an issue at all though. Given the choice, I'd take the 1 - 18".
But to port through the armrest hole, sub firing to the side would be easiest. If you chose to fire up, you will need to deaden your trunk lid. A lot. And while I recommend deadening your trunk lid anyway, but I personally don't like subs up in a trunk.
You could also do subs back, ports firing up through the rear deck 6/9" holes (if you meant taking them out). I think that would sound better too, having the waves bounce off the window, rather than straight through the middle of the car.
Well, how hard would it be to build a box ported for two 15's? I don't have that much need for my trunk, just for bookbag and my emergency cases and stuff like that. About how many cubes am I gonna need for two 15" HDC3's daily, mostly hip hop but a mix of everything including techno, rock, electro, etc.
POTATO!
Alright, so say I did one 15" for daily use...what am i looking at box and port-wise?
POTATO!
Do the 2 12"s, they should be louder than the single 15", on the same power.
do you have a killer deal on the hdc's ?
I've ever heared them, but I know there are dozens of subs in the market that can get loud.
I know nothing about trunk cars, so I can't help you.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
What else would be closer and cheaper than two AQ HDC3 12's?
POTATO!
How much power will you be pushing?
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Unknown yet, if I could afford an RF amp I'd say that, but I have no idea, probably an AQ amp that will equal the power
POTATO!
  • Who's Online   0 Members, 0 Anonymous, 620 Guests (See full list)
